Hi Everyone,
Actually I have different resolution video. Kindly tell me how I can get auto fit to the region…?
Hi Everyone,
Currently (1.7) you will want video in the same aspect ratio as the region in which you want to put it.
In 1.8 it will be possible to stretch videos (same as it’s available for images in 1.7), but still for the best result it would be best to have video aspect ratio match region aspect ratio.
I install 1.8.3 but still cannot strech video
There must be easy way to strech video
if the problem is windows media player, can we change to gom player or etc.
Please help this is very importent issue
Thank you
I don’t think Windows player supports it, but Android does.
That being said, it is still the best option to use video in the same aspect ratio as the region in which you will put it in.
