On Running Watchdog EXE directly only, following error is encountered on white labeled windows client version 1.8.1
Error keeps coming back and actual player never gets launched.
You should not need to launch watchdog directly as it should start with the player.
That being said, the path there seems to be the default path for standard release, if you’re having problems with your white label player please contact Spring Signage directly, as then we will be able to check that for you.
