Hi!
New to xibo! When using the layouts to build your campaign, can you use one particular layout multiple times in a campaign? For example:
Slide 1, slide 2, slide 1, slide 3, slide 1, slide 4, slide 1, etc. I want the information from slide 1 to be seen between each of the other slides.
When scheduling the campaign, it allows me to add the slides in the order described, but when you preview the layout, the duplicates of slide 1 fail to load (allowing for preview). Before I embark not the complexity of scheduling this campaign, I thought I’d check first.
Thanks!
