Dear All,
I need come out a digital tv display solution by tomorrow and i already install CMS also and to show on client Pc,
the problem here is how do i add web page to show on client Pc? i cant find any add in web page in CMS.
Thanks.
Dear All,
Thanks.
The manual is a really good place to start for these kinds of things.
Here’s a link to the webpage section:
So you create a layout, then a region, then inside the region you add your webpage.
Have a look at one of the guides to get started using the system:
Hi Alex,
Great !
Thanks for your Help and i found it
Thanks you so much.
