I have v1.8.11 installed using docker on CentOS v7. I can’t figure out nor understand the upgrade instructions to upgrade to v2.0.3.
I downloaded the latest xibo-docker.zip, do I extract that to a folder on the server’s root and CD into that folder and run “vendor/bin/phinx migrate -c phinx.php”.
Please explain as I’m not a Linux user.
copy using command cp -avrp path/to/old/share . replace path/to/old/share with your old share folder path from old xibo version you want to migrate (share fold is store xibo data persistent specify by docker-compose.yml) and copy config.env file to new xibo version folder.
now!! deploy xibo service with docker-compose up -d and see log docker-compose logs -f
if everything work find you success migrate xibo to new version
