When I upgrade from 2.2.3 to 2.3.0 then I always get the Screen: “The CMS is temporarily offline due to an update. Please contact your system administrator for information. Try to reload the page in a few minutes.”
Downgrading to 2.2.3 works only by restore the database with latest sql and not just replace the compse files and config.env. You have any idea??
If you have a particularly large database it can take a long time to run the migrations between 2.2.3 and 2.3.0 - maybe several hours in extreme cases.
You could truncate your log table ahead of time to speed things up, and also consider whether you need all of your proof of play stats and/or audit logs.
If all of those 3 tables are already small, perhaps it is something else and the output of docker-compose logs would be useful.
I waited some hours to upgrade from 2.2.3 to 2.3.0 but it did not work. All upgrades before worked easy. Is it possible to send you the docker compose logs via private Message?
cms-web_1 | == 20191205180116 AddPlaylistDashboardPageUserMigration: migrating
cms-web_1 |
cms-web_1 | In PdoAdapter.php line 134:
cms-web_1 |
cms-web_1 | SQLSTATE[HY000]: General error: 1364 Field 'edit' doesn't have a default value
Which we already know to be a problem - but I thought it would only effect MySQL 5.7 installs.
I can see you’re running mysqld 5.6.35 from the logs, so I will update the issue accordingly
