Hello Xibo Community,
i need help to upgrade the Xibo-CMS in the Docker Version. I’ve followed the guide to upgrade guide from 1.8 to 2.0. I’ve backuped all and extract the new xibo-docker.tar.gz to the /opt/xibo folder. I also edited the config.env with the mysql password and did the changes to the custom_ports.yml to do the reverse proxy.
The only problem is that i cant run docker-compose it tells me that he can’t decode and failed to excute.
Can anyone help me ?
