Hi. I’m currently looking to upgrade a Windows LAMP based installation of 1.7.4 to 1.8.10 running on Docker.
We are a vMware environment so I have already set up and configured some docker nodes using docker-machine with the vSphere driver and configured our vSphere environment to use vSphere storage for Docker so that I can mount the CMS library and DB volumes as persistent storage. I’m running the docker-compose commands from my Windows desktop and have the xibo installation folder set up with the shared subfolder containing my library backup and database export.
The problem is, after updating the docker-compose to use the vsphere driver for the volumes, the compose doesn’t seem to copy or use the docker upgrade files I put in the same folder as the compose config. Xibo launches into Docker fine and I can access it in the web but it is a generic brand new installation, not my upgrade.
I don’t see anything in the upgrade docs about using persistent storage while upgrading. Any help would be appreciated. docker-compose file is
version: "2.1"
services:
cms-db:
image: mysql:5.6
volumes:
- db_data:/var/lib/mysql
restart: always
environment:
- MYSQL_DATABASE=cms
- MYSQL_USER=cms
- MYSQL_RANDOM_ROOT_PASSWORD=yes
mem_limit: 1g
env_file: config.env
cms-xmr:
image: xibosignage/xibo-xmr:release-0.7
ports:
- "9505:9505"
restart: always
mem_limit: 256m
cms-web:
image: xibosignage/xibo-cms:release-1.8.10
volumes:
- cms_custom:/var/www/cms/custom
- backup:/var/www/backup
- cms_web_theme_custom:/var/www/cms/web/theme/custom
- cms_library:/var/www/cms/library
- cms_web_userscripts:/var/www/cms/web/userscripts
restart: always
links:
- cms-db:mysql
- cms-xmr:50001
environment:
- XMR_HOST=cms-xmr
ports:
- "8080:80"
mem_limit: 1g
volumes:
db_data:
driver: vsphere
driver_opts:
cms_custom:
driver: vsphere
driver_opts:
backup:
driver: vsphere
driver_opts:
driver: vsphere
driver_opts:
cms_library:
driver: vsphere
driver_opts:
driver: vsphere
driver_opts:
