Hi all,
I tried two times to upgrade My Xibo installation ( Ubuntu / Docker ) from 2.3.11 to 3.0.2 and 3.0.3.
The upgrade process is done right, the display are on and layouts are up.
But display do not show anymore in shedule tab, i can only schedule on groups no more on displays…
I tried to update the Xibo player from 2.57 to 3.301 but it does not change anything.
Any Idea ?
Hello and welcome to the Community.
Try running the SQL command as in the post below:
Thank you so much, it works like a charm, i can now see my displays in schedule !!
