Hi, thanks for the response.
Apparently when I try to delete an element of a layout it doesnt bring anything up on the log.
But I realized that the problem is not limited to just layouts. I cant delete anything including images from the library.
So I rerun the test and I tried deleting the layout elements which wont show anything and deleting an image from the media library which produces this message: Template Missing Exception Type: Xibo\Exception\ControllerNotImplemented,,ERROR
The cog on the Delete button just keeps spinning.
Please see the full log here:
81,71264b2,1/3/2018 15:30,WEB,/layout/status/2,GET,Layout has empty region,,ALERT
82,87f4d7c,1/3/2018 15:30,WEB,/layout/status/2,GET,Layout has empty region,,ALERT
83,0fcb23f,1/3/2018 15:30,WEB,/layout/status/2,GET,Layout has empty region,,ALERT
84,32f7610,1/3/2018 15:31,WEB,/layout/status/2,GET,Layout has empty region,,ALERT
85,a791d32,1/3/2018 15:31,WEB,/layout/status/2,GET,Layout has empty region,,ALERT
86,02dda19,1/3/2018 15:31,WEB,/layout/status/2,GET,Layout has empty region,,ALERT
87,0c2c134,1/3/2018 15:32,WEB,/layout/status/2,GET,Layout has empty region,,ALERT
88,bfc92df,1/3/2018 15:32,WEB,/layout/status/2,GET,Layout has empty region,,ALERT
89,6f13341,1/3/2018 15:32,WEB,/layout/status/2,GET,Layout has empty region,,ALERT
90,7c6db4c,1/3/2018 15:33,WEB,/layout/status/2,GET,Layout has empty region,,ALERT
91,077c2bb,1/3/2018 15:33,WEB,/layout/status/2,GET,Layout has empty region,,ALERT
92,6dbfa61,1/3/2018 15:33,WEB,/layout/status/2,GET,Layout has empty region,,ALERT
93,cf5e7ff,1/3/2018 15:34,WEB,/clock,GET,Template Missing Exception Type: Xibo\Exception\ControllerNotImplemented,,ERROR
94,34fb5f5,1/3/2018 15:34,WEB,/login/ping,GET,Template Missing Exception Type: Xibo\Exception\ControllerNotImplemented,,ERROR
95,d9f2a6b,1/3/2018 15:34,WEB,/layout/status/2,GET,Layout has empty region,,ALERT
96,d9f2a6b,1/3/2018 15:34,WEB,/layout/status/2,GET,Template Missing Exception Type: Xibo\Exception\ControllerNotImplemented,,ERROR
97,15eb0e9,1/3/2018 15:34,WEB,/layout/status/2,GET,Layout has empty region,,ALERT
98,21cc524,1/3/2018 15:34,WEB,/layout/status/2,GET,Layout has empty region,,ALERT
99,06326ce,1/3/2018 15:34,WEB,/layout/status/2,GET,Layout has empty region,,ALERT
100,00557c6,1/3/2018 15:35,WEB,/layout/status/2,GET,Layout has empty region,,ALERT
101,b9f03e6,1/3/2018 15:35,WEB,/layout/status/2,GET,Layout has empty region,,ALERT
102,ac01e37,1/3/2018 15:35,WEB,/layout/status/2,GET,Layout has empty region,,ALERT
103,84cb438,1/3/2018 15:36,WEB,/layout/status/2,GET,Layout has empty region,,ALERT
104,fa7d139,1/3/2018 15:36,WEB,/layout/status/2,GET,Layout has empty region,,ALERT
105,38a2158,1/3/2018 15:36,WEB,/layout/status/2,GET,Layout has empty region,,ALERT
106,32a0422,1/3/2018 15:37,WEB,/clock,GET,Template Missing Exception Type: Xibo\Exception\ControllerNotImplemented,,ERROR
107,ea6d924,1/3/2018 15:37,WEB,/login/ping,GET,Template Missing Exception Type: Xibo\Exception\ControllerNotImplemented,,ERROR
108,88f66e7,1/3/2018 15:37,WEB,/layout/status/2,GET,Layout has empty region,,ALERT
109,88f66e7,1/3/2018 15:37,WEB,/layout/status/2,GET,Template Missing Exception Type: Xibo\Exception\ControllerNotImplemented,,ERROR
110,c7ffd82,1/3/2018 15:37,WEB,/clock,GET,Template Missing Exception Type: Xibo\Exception\ControllerNotImplemented,,ERROR
111,62b63ec,1/3/2018 15:37,WEB,/login/ping,GET,Template Missing Exception Type: Xibo\Exception\ControllerNotImplemented,,ERROR
112,c56e83d,1/3/2018 15:37,WEB,/layout/status/2,GET,Layout has empty region,,ALERT
113,c56e83d,1/3/2018 15:37,WEB,/layout/status/2,GET,Template Missing Exception Type: Xibo\Exception\ControllerNotImplemented,,ERROR
114,4d90422,1/3/2018 15:37,WEB,/layout/status/2,GET,Layout has empty region,,ALERT
115,be3b403,1/3/2018 15:37,WEB,/clock,GET,Template Missing Exception Type: Xibo\Exception\ControllerNotImplemented,,ERROR
116,e944649,1/3/2018 15:37,WEB,/clock,GET,Template Missing Exception Type: Xibo\Exception\ControllerNotImplemented,,ERROR
117,4960d21,1/3/2018 15:37,WEB,/layout/status/2,GET,Layout has empty region,,ALERT
118,775e0ea,1/3/2018 15:37,WEB,/layout/status/2,GET,Layout has empty region,,ALERT
119,30faf50,1/3/2018 15:38,WEB,/layout/status/2,GET,Layout has empty region,,ALERT
120,4aab81c,1/3/2018 15:38,WEB,/layout/status/2,GET,Layout has empty region,,ALERT
121,4f7337a,1/3/2018 15:38,WEB,/layout/status/2,GET,Layout has empty region,,ALERT
Thank you again for the help.
