Unable to change Display Settings Profiles in 2.0.0
Since updating to 2.0.0 I’ve started encountering an odd issue in that I’m unable to make any changes to the Display Settings Profiles. I’m certain this was working fine before updating as I’d set some custom properties, but now if I go to Display Settings > Edit on any of the profiles, make any change (e.g. add a screenshot duration) and click Save, I’ll get the green confirmation notification that the changes were saved, but upon reopening the edit screen for that profile the changes will have reset to their initial setting.
Is anyone else encountering the same issue? I’m using the Docker image for Xibo and had processed an update from 1.8.12 to 2.0.0.
Many thanks
Tim
I have this same issue. I found the only workaround was creating new profiles and everything saves.
Same here! Noticed that, because the cursor position was set to unchanged with the V2.0.0 (and the mouse cursor was visible in the middle of the screen).
Got it work after Edit(ed) a Display. This somehow cleard a cache or something? At least I was able to save the Display Profile.
An issue has been identified and logged:
Thank you
