Hello, new to Xibo here. I tried using the Twitter Widget but I get a message saying “The Twitter Widget has not been configured yet, please ask your CMS Administrator to look at it for you.” What needs to be done to configure it, and how can we configure it?
Indeed it does require some configuration.
Please see http://xibo.org.uk/manual-tempel/en/media_module_twitter.html
Regarding search term - Advanced Twitter Feed
What do you have on appearance tab? Perhaps the tweet text is the same colour as the background?
You can also check CMS logs for errors (you might need to enable debugging on Report fault page first).
Also perhaps make sure it’s not curl issue - Using Tickers, Forecast, Twitter and other external resources that make use of HTTPS connections
