update interval under advanced is set to 5 min
Even if I set the duration to 120s and the update interval to 1 min I’m experiencing the same issue.
Update:
Caching is disabled on the display, running xibo from the cloud.
Enable caching of Web Resources? 0
Update2
Also: sometimes my layouts stop looping, and the screen remains stuck on 1 layout. I’ve enabled logging & audit trail
Update3
My connection to the CMS seems to be dropping, leading to a stop in looping (and updating) of layouts.
Currently the display status is signaled as “cloud” in the CMS, they android display is reachable via teamviewer.
Any idea on how to troubleshoot this? My DSCS9 has a wired internet connection
System was delivered runnig 1.8 v104. I’ve just pushed R108 to the CMS, hoping for an improvement
The system connects to the Twitter Search API, which provides “selected” tweets (not all) and there are limits set as to how often you can query it without being blocked.
If you’re running a local CMS with your own API key, you can lower that setting in the Module configuration for Twitter - but Twitter may limit you if they think you are making excessive requests.
We cache requests to the Twitter search API for 1 hour.
is a piece of info I missed, Are there any alternate solutions? I’m displaying a combination of 2 public accounts tweeting traffic info.
A 5min delay is OK, but 1h defeats the purpose
If you have your own Twitter API keys then we may be able to apply those to your CMS for you - in which case if Twitter block your keys for excessive searches then it won’t impact everyone else. You’d need to open a ticket with our support desk with the keys you want to use.
