The software im using is the following: Xampp 7.2.10 & xibo cms 1.8.11
OS : Windows
im having a issue with the Mcrypt Extension, since Xampp 7.2.10 is missing that extension.
I tried manually downloading the extension and copying it into the php/ext folder from xampp and write the extension into the php.ini file. Without result.
tried to use different versions of xampp aswell, didnt find the mcrypt extension either.
I am trying to get Xibo working on localhost please any advise?
hey steitzTo, i fixed the issue with this solution after 30minutes posting this issue. but now i keep getting spammed with the welcome message from the xibo cms 1.8.9 any solutions?
1.8.9 had that issue. You need to upgrade to 1.8.11.
Also ensure you don’t have “web” in the URL you’re using to access the CMS. If you do, you’ve not installed it correctly and you will continue to experience these issues even after upgrade.
You need to setup an alias or change the document root for Apache.
