Hi all,
I’m in the process of upgrading from 1.7.5 to 1.8.2. My original config was running on Ubuntu x64 14.04 LTS with XAMPP 5.6.14-4. I have migrated to a test machine with the same version of Ubuntu, however I am using Docker 17.06.2-ce and have followed the Xibo guides (Switch to Docker and Docker on Linux). After some fiddling I was able to get Docker installed, my data migrated from the old install, composing the Xibo Docker instance and being able to login to the Xibo web interface. I am currently at the upgrade wizard and am having issues. I ran into the same issue as in this post, getting stuck on the same step even (141). I followed the same advice & skipped the step. I hit several other steps that had similar errors (typically they indicated a duplicate key, column, row, etc); specifically steps 198, 203, 209, 211, 213, 215*, 216, 218, 222, 223, & 232.
However, step 233 gives the error, “SQLSTATE[42000]: Syntax error or access violation: 1091 Can’t DROP ‘LastPage’; check that column/key exists”.
Any advice would be greatly appreciated.
