Hello!
I’ve done an installation as usual on my Synology Diskstation and the installation routine passes fine.
When everything ist done i get an error message i don’t know.
After logging in there is the Message:
Schrift Datei nicht lesbar!
Font file unreadable!
I had a great time getting 1.8 to run on a Synology box. However, I did not run into that one. At first I would think this to be a permissins isssue. DMS version? PHP Version?
Have you set the server type on the site to Apache? I think it is defaults to NGINX.
The default loading path should be to the “web” folder under the Xibo folder. (Make sure you are not pointing the domain to the web servers “web” folder) From there you should be usnig a .htaccess file for URL re-writing (RewriteEngine On), and of course some rule on how to re-write the URLS. Once that is configured correctly. I think you error will be no longer.
I think next we should look at your .htaccess file and how you have that configured. If you don’t mind uploading that to dropbox or something, while removing anything you would not like to have public, then providing a link to the file, that would be great.
It could be any .htaccess file within the path. So if there is one in /xibo and one in /xibo/web then both will be processed. I would recommend only one if you have more than one. If you just have one then yes, it would be the one you are seeing in /xibo/web.
not working. same problem.
if i am browsing to my server ip then there ist the startsite from my synology
1.7.8 is runing good on my 1512+.
but i would like to try 1.8.
so i installed the same way and installation worked fine.
there is a database in the phpmyadmin.
and i can log in with my user name.
but then always the same message:
so now i hav no more idea!
thanks for helping me
i’m going to try every reply.
Can’t read font file suggests to me a filesystem permissions issue. Make sure your webserver user has read permissions to the whole CMS installation, and write permissions to the library and cache directories.
