hi,
I installed under windows server 2012 r2 64, xampp (xampp-windows-x64-7.3.5-0-VC15) with php 7.3.5.
I used the ZeroMq extension php_zmq-1.1.3-7.2-ts-vc15-x64.
I put libzmq.dll and php_zmq.dll in \xampp\php \ ext and also libzmq.dll in \xampp\php.
I have always I! in front of ZeroMq when installing Xibo 2.0.1.
Did I use the right packages???
do you have the Microsoft Visual C++ 2017 Runtime in the x86 and x64 version installed at your System?
If not, please install it .
Maybe your version of the ZeroMq Package is wrong? Yours is for PHP 7.2, but you have 7.3 installed.
This are the latest Realeases of ZeroM@
Non-Thread-Save:
php_zmq-1.1.3-7.2-nts-vc15-x64.zip
php_zmq-1.1.3-7.2-nts-vc15-x86.zip
TreadSave:
php_zmq-1.1.3-7.2-ts-vc15-x64.zip
php_zmq-1.1.3-7.2-ts-vc15-x86.zip
Look at your PHP-Info for the Information of:
ServerArchitecture: x86 or x64?
Thread Savety: Enable or Disable?
so choose the right package and install it.
Here my how-to in german:
Greetings from Germany
Torsten
hi,
Thanks SteitzTo, after installing Microsoft Visual C++ 2017 Everything works well
Nice to hear, that i can help you.
Greetings
Torsten
