Translation Dutch
Is it possible to put the Dutch translation as default nl_NL in Xibo?
Thanks for the message. the default Language is English but you can set this to nl after the installation is complete. You will find this option in the Settings option under the Regional tab. Make sure to untick the Detect Browser Language option if you are using a different language for your browser. refreshing the page should then show the change of Language.
