TizenOS and how to install Player to TV?
Xibo for Tizen_v4_R408
Installation Method
Docker and computer
Operating System
Newest TizenOS
I just can not install this Xibo player to the Samsung TV TizenOS. I do read the guide and made that SSSP Folder and inside that stuff like it was in guided..
Highly uplifted mind if somebody could help me out:)!
Roope
TV Mode is: Samsung 55” U8095F 4K (2025).
Hi @Roope , Welcome to the Xibo Community!
Unfortunately it is not possible to install the Xibo for Tizen player on your U8095F display as it is a standard TV rather than a Digital Signage display.
The list of supported Tizen displays can be found here: Tizen list of supported monitors | Xibo Digital Signage
Arg… What a shock :frowning: So there is no way to show stuff on that “Telly” :)?
I do highly thx to you Frazer for the help!!
Roope
You would need to connect an external device to this TV in order to run Xibo on it. For example, the SBB-SSN | SBB-SS08NL1/UE | null can be used if you need to run Xibo for Tizen, or you can use an Android, Windows or ChromeOS device. You would then install the relevant Xibo player app on the external device instead.
Ok, could you tell more about those? Is it possible to use this device to show Xibo stuff? Google Chromecast Full HD (4. gen)
Or what would be the easy choice to make it running smoothly??
I just need to connect only one display or this TV to show content.
Thx Frazer!
Roope
Yes, you can use the Xibo for ChromeOS player on ChromeOS devices: Xibo for ChromeOS | Xibo Signage
Please do note though, a Chromecast is not a ChromeOS device, so it is not compatible.
Please see the following list of approved devices, as an example: Xibo for ChromeOS | Xibo Signage
You could also repurpose existing PC hardware with ChromeOS Flex: Certified models list - ChromeOS Flex Help
