Tizen monitor QMR-?
I have a question regarding Tizen and this list: Tizen list of supported monitors | Xibo Digital Signage
As part of the QMR series support, are the QMR-B, QMR-C, and QMR-A models also supported?
Hi Jakub.
The QMR-A and B versions are the same, so they should be supported. The trailing letter can refer to the country it is sold in, but they should be the same model and therefore both supported.
I can’t locate a QMR-C, can you show me where you are seeing that model?
On a side note, if you see a model with a T listed at the end, that specifically means it is a touch screen model. So for example a QBR and QBR-T are the same, but the latter has a touch screen.
Thanks for answer.
QMR-C … my mistake :wink:
haha ok no worries :slightly_smiling_face:
