Hello!
I have a Ticker set up running off a Dataset. 4 Slides, each slide corresponding to one dataset row.
It will cycle through the 4 slides/rows and then come back to the first one again at the end, before moving to the next playlist item.
I figured the timing was off, but no matter if I set an overall duration or duration per item, it will show the first slide again for a short period.
The Item duration is 6 Seconds, Speed 1, Effect set to ‘No transition’.
I timed it manually, noticing that each item is only displayed for 5 seconds, so it finishes early, filling the remaining time with the first slide/row content.
This is what I want:
RowA > RowB > RowC > RowD > Next playlist Item
6sec > 6sec > 6sec > 6sec
This is what is happening:
RowA > RowB > RowC > RowD > RowA > Next playlist Item
5sec > 5sec > 5sec > 5sec > 4sec
