Text widget problem
Hi I cant edit after latest xibo upgrade with internet explorer text widget items if widget has name on options tab, without name everything works well.
Just to confirm that’s 1.8.10 CMS?
I’m not sure how the widget name can impact your ability to edit the text, it looks to me like the CKEditor isn’t displayed at all there.
I do not have that problem in IE, I just checked now.
Could you confirm that it isn’t cache issue by clearing IE cache please?
I assume or other browsers work fine?
Hi Cache cleaning does not help other browsers works fine but company does not allow other browsers than IE
only fix was cleaning names from widgets
