Do you have a how to on creating templates? I created a layout in Photoshop, but the issue I’m having is with placing a local video within an area. I can not seem to get the size of the video right.
Just what you should and shouldn’t do when creating a template, how should you use backgrounds compared to layer images.
What I did was created a layout in PS and used it as a background image. I’m not sure if that’s the proper way or not.
Below is a link to the Templates section of the Xibo Manual. You can also use this link to access other Manuals and Documentation to help you get started with Xibo.
