Tasks scheduling v.4.3 give errors messages in logs
having a look to logs I’ve noted, recurrent messages, with level as INFO: “run: CRON syntax error for taskId 14, e: 6 is not a valid position”. This message is the same for tasks 13, 10, 3 and 2.
Asking ChatGPT it forward me to table task table in cms db and highlighted that tasks in error are the one with 6 data in “schedule” field (instead of 5).
Because this filed is used to feed cron I guess that updating from version 4.2 to 4.3 has touch this component because in previous version (that I still have in my NAS) this issue doesn’t happen.
Honestly I don’t know if the tasks affected by this “INFO” message are properly running or not, but I think you could be interested.
Thank you, bye.
