| 2018-10-29 09:24:28 |
stdout |
Version: â5.6.39â socket: â/var/run/mysqld/mysqld.sockâ port: 3306 MySQL Community Server (GPL) |
stdout |
2018-10-29 09:24:27 1 [Note] mysqld: ready for connections. |
| 2018-10-29 09:24:27 |
stdout |
2018-10-29 09:24:27 1 [Note] Event Scheduler: Loaded 0 events |
| 2018-10-29 09:24:26 |
stdout |
2018-10-29 09:24:26 1 [Warning] âproxies_privâ entry â@ root@cms-db2â ignored in --skip-name-resolve mode. |
stdout |
2018-10-29 09:24:26 1 [Note] Server socket created on IP: â::â. |
stdout |
2018-10-29 09:24:26 1 [Note] - â::â resolves to â::â; |
stdout |
2018-10-29 09:24:26 1 [Note] IPv6 is available. |
stdout |
2018-10-29 09:24:26 1 [Note] Server hostname (bind-address): â*â; port: 3306 |
stdout |
2018-10-29 09:24:26 1 [Note] InnoDB: 5.6.39 started; log sequence number 5230838672 |
stdout |
2018-10-29 09:24:26 1 [Note] InnoDB: Waiting for purge to start |
stdout |
2018-10-29 09:24:26 1 [Note] InnoDB: 128 rollback segment(s) are active. |
| 2018-10-29 09:24:24 |
stdout |
2018-10-29 09:24:24 1 [Note] InnoDB: from the doublewrite buffer⌠|
stdout |
2018-10-29 09:24:24 1 [Note] InnoDB: Restoring possible half-written data pages |
| 2018-10-29 09:24:23 |
stdout |
2018-10-29 09:24:23 1 [Note] InnoDB: Reading tablespace information from the .ibd files⌠|
stdout |
2018-10-29 09:24:23 1 [Note] InnoDB: Starting crash recovery. |
stdout |
2018-10-29 09:24:23 1 [Note] InnoDB: Database was not shutdown normally! |
stdout |
2018-10-29 09:24:23 1 [Note] InnoDB: The log sequence numbers 5230838662 and 5230838662 in ibdata files do not match the log sequence number 5230838672 in the ib_logfiles! |
stdout |
2018-10-29 09:24:23 1 [Note] InnoDB: Highest supported file format is Barracuda. |
| 2018-10-29 09:24:22 |
stdout |
2018-10-29 09:24:22 1 [Note] InnoDB: Completed initialization of buffer pool |
stdout |
2018-10-29 09:24:22 1 [Note] InnoDB: Initializing buffer pool, size = 128.0M |
stdout |
2018-10-29 09:24:22 1 [Note] InnoDB: Using CPU crc32 instructions |
stdout |
2018-10-29 09:24:22 1 [Note] InnoDB: Using Linux native AIO |
stdout |
2018-10-29 09:24:22 1 [Note] InnoDB: Compressed tables use zlib 1.2.3 |
stdout |
2018-10-29 09:24:22 1 [Note] InnoDB: Memory barrier is not used |
stdout |
2018-10-29 09:24:22 1 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins |
stdout |
2018-10-29 09:24:22 1 [Note] InnoDB: The InnoDB memory heap is disabled |
stdout |
2018-10-29 09:24:22 1 [Note] InnoDB: Using atomics to ref count buffer pool pages |
stdout |
2018-10-29 09:24:22 1 [Note] Plugin âFEDERATEDâ is disabled. |
stdout |
2018-10-29 09:24:22 0 [Note] mysqld (mysqld 5.6.39) starting as process 1 ⌠|
stdout |
2018-10-29 09:24:22 0 [Warning] TIMESTAMP with implicit DEFAULT value is deprecated. Please use --explicit_defaults_for_timestamp server option (see documentation for more details). |
| 2018-10-29 09:23:03 |
stdout |
stdout |
2018-10-29 09:23:03 1 [Note] mysqld: Shutdown complete |
stdout |
2018-10-29 09:23:03 1 [Note] Shutting down plugin âbinlogâ |
| 2018-10-29 09:23:02 |
stdout |
2018-10-29 09:23:02 1 [Note] Shutting down plugin âmysql_native_passwordâ |
stdout |
2018-10-29 09:23:02 1 [Note] Shutting down plugin âmysql_old_passwordâ |
stdout |
2018-10-29 09:23:02 1 [Note] Shutting down plugin âsha256_passwordâ |
stdout |
2018-10-29 09:23:02 1 [Note] Shutting down plugin âCSVâ |
stdout |
2018-10-29 09:23:02 1 [Note] Shutting down plugin âMEMORYâ |
stdout |
2018-10-29 09:23:02 1 [Note] Shutting down plugin âMyISAMâ |
stdout |
2018-10-29 09:23:02 1 [Note] Shutting down plugin âMRG_MYISAMâ |
stdout |
2018-10-29 09:23:02 1 [Note] Shutting down plugin âARCHIVEâ |
stdout |
2018-10-29 09:23:02 1 [Note] Shutting down plugin âBLACKHOLEâ |
stdout |
2018-10-29 09:23:02 1 [Note] InnoDB: Shutdown completed; log sequence number 5274495201 |
| 2018-10-29 09:22:57 |
stdout |
2018-10-29 09:22:57 1 [Note] InnoDB: Starting shutdown⌠|
stdout |
2018-10-29 09:22:57 1 [Note] InnoDB: FTS optimize thread exiting. |
stdout |
2018-10-29 09:22:57 1 [Note] Shutting down plugin âInnoDBâ |
stdout |
2018-10-29 09:22:57 1 [Note] Shutting down plugin âINNODB_TRXâ |
stdout |
2018-10-29 09:22:57 1 [Note] Shutting down plugin âINNODB_LOCKSâ |
stdout |
2018-10-29 09:22:57 1 [Note] Shutting down plugin âINNODB_LOCK_WAITSâ |
stdout |
2018-10-29 09:22:57 1 [Note] Shutting down plugin âINNODB_CMPâ |
stdout |
2018-10-29 09:22:57 1 [Note] Shutting down plugin âINNODB_CMP_RESETâ |
stdout |
2018-10-29 09:22:57 1 [Note] Shutting down plugin âINNODB_CMPMEMâ |
stdout |
2018-10-29 09:22:57 1 [Note] Shutting down plugin âINNODB_CMPMEM_RESETâ |
stdout |
2018-10-29 09:22:57 1 [Note] Shutting down plugin âINNODB_CMP_PER_INDEXâ |
stdout |
2018-10-29 09:22:57 1 [Note] Shutting down plugin âINNODB_CMP_PER_INDEX_RESETâ |
stdout |
2018-10-29 09:22:57 1 [Note] Shutting down plugin âINNODB_BUFFER_PAGEâ |
stdout |
2018-10-29 09:22:57 1 [Note] Shutting down plugin âINNODB_BUFFER_PAGE_LRUâ |
stdout |
2018-10-29 09:22:57 1 [Note] Shutting down plugin âINNODB_BUFFER_POOL_STATSâ |
stdout |
2018-10-29 09:22:57 1 [Note] Shutting down plugin âINNODB_METRICSâ |
stdout |
2018-10-29 09:22:57 1 [Note] Shutting down plugin âINNODB_FT_DEFAULT_STOPWORDâ |
stdout |
2018-10-29 09:22:57 1 [Note] Shutting down plugin âINNODB_FT_DELETEDâ |
stdout |
2018-10-29 09:22:57 1 [Note] Shutting down plugin âINNODB_FT_BEING_DELETEDâ |
stdout |
2018-10-29 09:22:57 1 [Note] Shutting down plugin âINNODB_FT_CONFIGâ |
stdout |
2018-10-29 09:22:57 1 [Note] Shutting down plugin âINNODB_FT_INDEX_CACHEâ |
stdout |
2018-10-29 09:22:57 1 [Note] Shutting down plugin âINNODB_FT_INDEX_TABLEâ |
stdout |
2018-10-29 09:22:57 1 [Note] Shutting down plugin âINNODB_SYS_TABLESâ |
stdout |
2018-10-29 09:22:57 1 [Note] Shutting down plugin âINNODB_SYS_TABLESTATSâ |
stdout |
2018-10-29 09:22:57 1 [Note] Shutting down plugin âINNODB_SYS_INDEXESâ |
stdout |
2018-10-29 09:22:57 1 [Note] Shutting down plugin âINNODB_SYS_COLUMNSâ |
stdout |
2018-10-29 09:22:57 1 [Note] Shutting down plugin âINNODB_SYS_FIELDSâ |
stdout |
2018-10-29 09:22:57 1 [Note] Shutting down plugin âINNODB_SYS_FOREIGNâ |
stdout |
2018-10-29 09:22:57 1 [Note] Shutting down plugin âINNODB_SYS_FOREIGN_COLSâ |
stdout |
2018-10-29 09:22:57 1 [Note] Shutting down plugin âINNODB_SYS_TABLESPACESâ |
stdout |
2018-10-29 09:22:57 1 [Note] Shutting down plugin âINNODB_SYS_DATAFILESâ |
stdout |
2018-10-29 09:22:57 1 [Note] Shutting down plugin âPERFORMANCE_SCHEMAâ |
stdout |
2018-10-29 09:22:57 1 [Note] Shutting down plugin âpartitionâ |
stdout |
2018-10-29 09:22:57 1 [Note] Binlog end |
stdout |
2018-10-29 09:22:57 1 [Note] Forcefully disconnecting 0 remaining clients |
stdout |
2018-10-29 09:22:57 1 [Note] Shutting down slave threads |
stdout |
2018-10-29 09:22:57 1 [Note] Event Scheduler: Purging the queue. 0 events |
stdout |
2018-10-29 09:22:57 1 [Note] Giving 0 client threads a chance to die gracefully |
stdout |
stdout |
2018-10-29 09:22:57 1 [Note] mysqld: Normal shutdown |
| 2018-10-08 10:22:52 |
stdout |
stdout |
2018-10-08 10:22:52 1 [Note] mysqld: ready for connections. |
stdout |
2018-10-08 10:22:52 1 [Note] Event Scheduler: Loaded 0 events |
stdout |
2018-10-08 10:22:52 1 [Warning] âproxies_privâ entry â@ root@cms-db2â ignored in --skip-name-resolve mode. |
stdout |
2018-10-08 10:22:52 1 [Note] Server socket created on IP: â::â. |
stdout |
2018-10-08 10:22:52 1 [Note] - â::â resolves to â::â; |
stdout |
2018-10-08 10:22:52 1 [Note] IPv6 is available. |
stdout |
2018-10-08 10:22:52 1 [Note] Server hostname (bind-address): â*â; port: 3306 |
stdout |
2018-10-08 10:22:52 1 [Note] InnoDB: 5.6.39 started; log sequence number 5230838692 |
| 2018-10-08 10:22:51 |
stdout |
2018-10-08 10:22:51 1 [Note] InnoDB: Waiting for purge to start |
stdout |
2018-10-08 10:22:51 1 [Note] InnoDB: 128 rollback segment(s) are active. |
stdout |
2018-10-08 10:22:51 1 [Note] InnoDB: Highest supported file format is Barracuda. |
stdout |
2018-10-08 10:22:51 1 [Note] InnoDB: Completed initialization of buffer pool |
stdout |
2018-10-08 10:22:51 1 [Note] InnoDB: Initializing buffer pool, size = 128.0M |
stdout |
2018-10-08 10:22:51 1 [Note] InnoDB: Using CPU crc32 instructions |
stdout |
2018-10-08 10:22:51 1 [Note] InnoDB: Using Linux native AIO |
stdout |
2018-10-08 10:22:51 1 [Note] InnoDB: Compressed tables use zlib 1.2.3 |
stdout |
2018-10-08 10:22:51 1 [Note] InnoDB: Memory barrier is not used |
stdout |
2018-10-08 10:22:51 1 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins |
stdout |
2018-10-08 10:22:51 1 [Note] InnoDB: The InnoDB memory heap is disabled |
stdout |
2018-10-08 10:22:51 1 [Note] InnoDB: Using atomics to ref count buffer pool pages |
stdout |
2018-10-08 10:22:51 1 [Note] Plugin âFEDERATEDâ is disabled. |
stdout |
2018-10-08 10:22:51 0 [Note] mysqld (mysqld 5.6.39) starting as process 1 ⌠|
stdout |
2018-10-08 10:22:51 0 [Warning] TIMESTAMP with implicit DEFAULT value is deprecated. Please use --explicit_defaults_for_timestamp server option (see documentation for more details). |
| 2018-10-08 10:22:46 |
stdout |
stdout |
2018-10-08 10:22:46 1 [Note] mysqld: Shutdown complete |
stdout |
2018-10-08 10:22:46 1 [Note] Shutting down plugin âbinlogâ |
stdout |
2018-10-08 10:22:46 1 [Note] Shutting down plugin âmysql_native_passwordâ |
stdout |
2018-10-08 10:22:46 1 [Note] Shutting down plugin âmysql_old_passwordâ |
stdout |
2018-10-08 10:22:46 1 [Note] Shutting down plugin âsha256_passwordâ |
stdout |
2018-10-08 10:22:46 1 [Note] Shutting down plugin âCSVâ |
stdout |
2018-10-08 10:22:46 1 [Note] Shutting down plugin âMEMORYâ |
stdout |
2018-10-08 10:22:46 1 [Note] Shutting down plugin âMyISAMâ |
stdout |
2018-10-08 10:22:46 1 [Note] Shutting down plugin âMRG_MYISAMâ |
stdout |
2018-10-08 10:22:46 1 [Note] Shutting down plugin âARCHIVEâ |
stdout |
2018-10-08 10:22:46 1 [Note] Shutting down plugin âBLACKHOLEâ |
stdout |
2018-10-08 10:22:46 1 [Note] InnoDB: Shutdown completed; log sequence number 5230838692 |
| 2018-10-08 10:22:44 |
stdout |
2018-10-08 10:22:44 1 [Note] InnoDB: Starting shutdown⌠|
stdout |
2018-10-08 10:22:44 1 [Note] InnoDB: FTS optimize thread exiting. |
stdout |
2018-10-08 10:22:44 1 [Note] Shutting down plugin âInnoDBâ |
stdout |
2018-10-08 10:22:44 1 [Note] Shutting down plugin âINNODB_TRXâ |
stdout |
2018-10-08 10:22:44 1 [Note] Shutting down plugin âINNODB_LOCKSâ |
stdout |
2018-10-08 10:22:44 1 [Note] Shutting down plugin âINNODB_LOCK_WAITSâ |
stdout |
2018-10-08 10:22:44 1 [Note] Shutting down plugin âINNODB_CMPâ |
stdout |
2018-10-08 10:22:44 1 [Note] Shutting down plugin âINNODB_CMP_RESETâ |
stdout |
2018-10-08 10:22:44 1 [Note] Shutting down plugin âINNODB_CMPMEMâ |
stdout |
2018-10-08 10:22:44 1 [Note] Shutting down plugin âINNODB_CMPMEM_RESETâ |
stdout |
2018-10-08 10:22:44 1 [Note] Shutting down plugin âINNODB_CMP_PER_INDEXâ |
stdout |
2018-10-08 10:22:44 1 [Note] Shutting down plugin âINNODB_CMP_PER_INDEX_RESETâ |
stdout |
2018-10-08 10:22:44 1 [Note] Shutting down plugin âINNODB_BUFFER_PAGEâ |
stdout |
2018-10-08 10:22:44 1 [Note] Shutting down plugin âINNODB_BUFFER_PAGE_LRUâ |
stdout |
2018-10-08 10:22:44 1 [Note] Shutting down plugin âINNODB_BUFFER_POOL_STATSâ |
stdout |
2018-10-08 10:22:44 1 [Note] Shutting down plugin âINNODB_METRICSâ |
stdout |
2018-10-08 10:22:44 1 [Note] Shutting down plugin âINNODB_FT_DEFAULT_STOPWORDâ |
stdout |
2018-10-08 10:22:44 1 [Note] Shutting down plugin âINNODB_FT_DELETEDâ |
stdout |
2018-10-08 10:22:44 1 [Note] Shutting down plugin âINNODB_FT_BEING_DELETEDâ |
stdout |
2018-10-08 10:22:44 1 [Note] Shutting down plugin âINNODB_FT_CONFIGâ |
stdout |
2018-10-08 10:22:44 1 [Note] Shutting down plugin âINNODB_FT_INDEX_CACHEâ |
stdout |
2018-10-08 10:22:44 1 [Note] Shutting down plugin âINNODB_FT_INDEX_TABLEâ |
stdout |
2018-10-08 10:22:44 1 [Note] Shutting down plugin âINNODB_SYS_TABLESâ |
stdout |
2018-10-08 10:22:44 1 [Note] Shutting down plugin âINNODB_SYS_TABLESTATSâ |
stdout |
2018-10-08 10:22:44 1 [Note] Shutting down plugin âINNODB_SYS_INDEXESâ |
stdout |
2018-10-08 10:22:44 1 [Note] Shutting down plugin âINNODB_SYS_COLUMNSâ |
stdout |
2018-10-08 10:22:44 1 [Note] Shutting down plugin âINNODB_SYS_FIELDSâ |
stdout |
2018-10-08 10:22:44 1 [Note] Shutting down plugin âINNODB_SYS_FOREIGNâ |
stdout |
2018-10-08 10:22:44 1 [Note] Shutting down plugin âINNODB_SYS_FOREIGN_COLSâ |
stdout |
2018-10-08 10:22:44 1 [Note] Shutting down plugin âINNODB_SYS_TABLESPACESâ |
stdout |
2018-10-08 10:22:44 1 [Note] Shutting down plugin âINNODB_SYS_DATAFILESâ |
stdout |
2018-10-08 10:22:44 1 [Note] Shutting down plugin âPERFORMANCE_SCHEMAâ |
stdout |
2018-10-08 10:22:44 1 [Note] Shutting down plugin âpartitionâ |
stdout |
2018-10-08 10:22:44 1 [Note] Binlog end |
stdout |
2018-10-08 10:22:44 1 [Note] Forcefully disconnecting 0 remaining clients |
stdout |
2018-10-08 10:22:44 1 [Note] Shutting down slave threads |
stdout |
2018-10-08 10:22:44 1 [Note] Event Scheduler: Purging the queue. 0 events |
stdout |
2018-10-08 10:22:44 1 [Note] Giving 0 client threads a chance to die gracefully |
stdout |
stdout |
2018-10-08 10:22:44 1 [Note] mysqld: Normal shutdown |
| 2018-10-08 10:18:35 |
stdout |
stdout |
2018-10-08 10:18:35 1 [Note] mysqld: ready for connections. |
stdout |
2018-10-08 10:18:35 1 [Note] Event Scheduler: Loaded 0 events |
stdout |
2018-10-08 10:18:35 1 [Warning] âproxies_privâ entry â@ root@cms-db2â ignored in --skip-name-resolve mode. |
stdout |
2018-10-08 10:18:35 1 [Note] Server socket created on IP: â::â. |
stdout |
2018-10-08 10:18:35 1 [Note] - â::â resolves to â::â; |
stdout |
2018-10-08 10:18:35 1 [Note] IPv6 is available. |
stdout |
2018-10-08 10:18:35 1 [Note] Server hostname (bind-address): â*â; port: 3306 |
stdout |
2018-10-08 10:18:35 1 [Note] InnoDB: 5.6.39 started; log sequence number 5230838682 |
stdout |
2018-10-08 10:18:35 1 [Note] InnoDB: Waiting for purge to start |
stdout |
2018-10-08 10:18:35 1 [Note] InnoDB: 128 rollback segment(s) are active. |
stdout |
2018-10-08 10:18:35 1 [Note] InnoDB: Highest supported file format is Barracuda. |
stdout |
2018-10-08 10:18:35 1 [Note] InnoDB: Completed initialization of buffer pool |
stdout |
2018-10-08 10:18:35 1 [Note] InnoDB: Initializing buffer pool, size = 128.0M |
stdout |
2018-10-08 10:18:35 1 [Note] InnoDB: Using CPU crc32 instructions |
stdout |
2018-10-08 10:18:35 1 [Note] InnoDB: Using Linux native AIO |
stdout |
2018-10-08 10:18:35 1 [Note] InnoDB: Compressed tables use zlib 1.2.3 |
stdout |
2018-10-08 10:18:35 1 [Note] InnoDB: Memory barrier is not used |
stdout |
2018-10-08 10:18:35 1 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins |
stdout |
2018-10-08 10:18:35 1 [Note] InnoDB: The InnoDB memory heap is disabled |
stdout |
2018-10-08 10:18:35 1 [Note] InnoDB: Using atomics to ref count buffer pool pages |
stdout |
2018-10-08 10:18:35 1 [Note] Plugin âFEDERATEDâ is disabled. |
stdout |
2018-10-08 10:18:35 0 [Note] mysqld (mysqld 5.6.39) starting as process 1 ⌠|
stdout |
2018-10-08 10:18:35 0 [Warning] TIMESTAMP with implicit DEFAULT value is deprecated. Please use --explicit_defaults_for_timestamp server option (see documentation for more details). |
| 2018-10-08 10:17:39 |
stdout |
stdout |
2018-10-08 10:17:39 1 [Note] mysqld: Shutdown complete |
stdout |
2018-10-08 10:17:39 1 [Note] Shutting down plugin âbinlogâ |
stdout |
2018-10-08 10:17:39 1 [Note] Shutting down plugin âmysql_native_passwordâ |
stdout |
2018-10-08 10:17:39 1 [Note] Shutting down plugin âmysql_old_passwordâ |
stdout |
2018-10-08 10:17:39 1 [Note] Shutting down plugin âsha256_passwordâ |
stdout |
2018-10-08 10:17:39 1 [Note] Shutting down plugin âCSVâ |
stdout |
2018-10-08 10:17:39 1 [Note] Shutting down plugin âMEMORYâ |
stdout |
2018-10-08 10:17:39 1 [Note] Shutting down plugin âMyISAMâ |
stdout |
2018-10-08 10:17:39 1 [Note] Shutting down plugin âMRG_MYISAMâ |
stdout |
2018-10-08 10:17:39 1 [Note] Shutting down plugin âARCHIVEâ |
stdout |
2018-10-08 10:17:39 1 [Note] Shutting down plugin âBLACKHOLEâ |
stdout |
2018-10-08 10:17:39 1 [Note] InnoDB: Shutdown completed; log sequence number 5230838682 |
| 2018-10-08 10:17:37 |
stdout |
2018-10-08 10:17:37 1 [Note] InnoDB: Starting shutdown⌠|
stdout |
2018-10-08 10:17:37 1 [Note] InnoDB: FTS optimize thread exiting. |
stdout |
2018-10-08 10:17:37 1 [Note] Shutting down plugin âInnoDBâ |
stdout |
2018-10-08 10:17:37 1 [Note] Shutting down plugin âINNODB_TRXâ |
stdout |
2018-10-08 10:17:37 1 [Note] Shutting down plugin âINNODB_LOCKSâ |
stdout |
2018-10-08 10:17:37 1 [Note] Shutting down plugin âINNODB_LOCK_WAITSâ |
stdout |
2018-10-08 10:17:37 1 [Note] Shutting down plugin âINNODB_CMPâ |
stdout |
2018-10-08 10:17:37 1 [Note] Shutting down plugin âINNODB_CMP_RESETâ |
stdout |
2018-10-08 10:17:37 1 [Note] Shutting down plugin âINNODB_CMPMEMâ |
stdout |
2018-10-08 10:17:37 1 [Note] Shutting down plugin âINNODB_CMPMEM_RESETâ |
stdout |
2018-10-08 10:17:37 1 [Note] Shutting down plugin âINNODB_CMP_PER_INDEXâ |
stdout |
2018-10-08 10:17:37 1 [Note] Shutting down plugin âINNODB_CMP_PER_INDEX_RESETâ |
stdout |
2018-10-08 10:17:37 1 [Note] Shutting down plugin âINNODB_BUFFER_PAGEâ |
stdout |
2018-10-08 10:17:37 1 [Note] Shutting down plugin âINNODB_BUFFER_PAGE_LRUâ |
stdout |
2018-10-08 10:17:37 1 [Note] Shutting down plugin âINNODB_BUFFER_POOL_STATSâ |
stdout |
2018-10-08 10:17:37 1 [Note] Shutting down plugin âINNODB_METRICSâ |
stdout |
2018-10-08 10:17:37 1 [Note] Shutting down plugin âINNODB_FT_DEFAULT_STOPWORDâ |
stdout |
2018-10-08 10:17:37 1 [Note] Shutting down plugin âINNODB_FT_DELETEDâ |
stdout |
2018-10-08 10:17:37 1 [Note] Shutting down plugin âINNODB_FT_BEING_DELETEDâ |
stdout |
2018-10-08 10:17:37 1 [Note] Shutting down plugin âINNODB_FT_CONFIGâ |
stdout |
2018-10-08 10:17:37 1 [Note] Shutting down plugin âINNODB_FT_INDEX_CACHEâ |
stdout |
2018-10-08 10:17:37 1 [Note] Shutting down plugin âINNODB_FT_INDEX_TABLEâ |
stdout |
2018-10-08 10:17:37 1 [Note] Shutting down plugin âINNODB_SYS_TABLESâ |
stdout |
2018-10-08 10:17:37 1 [Note] Shutting down plugin âINNODB_SYS_TABLESTATSâ |
stdout |
2018-10-08 10:17:37 1 [Note] Shutting down plugin âINNODB_SYS_INDEXESâ |
stdout |
2018-10-08 10:17:37 1 [Note] Shutting down plugin âINNODB_SYS_COLUMNSâ |
stdout |
2018-10-08 10:17:37 1 [Note] Shutting down plugin âINNODB_SYS_FIELDSâ |
stdout |
2018-10-08 10:17:37 1 [Note] Shutting down plugin âINNODB_SYS_FOREIGNâ |
stdout |
2018-10-08 10:17:37 1 [Note] Shutting down plugin âINNODB_SYS_FOREIGN_COLSâ |
stdout |
2018-10-08 10:17:37 1 [Note] Shutting down plugin âINNODB_SYS_TABLESPACESâ |
stdout |
2018-10-08 10:17:37 1 [Note] Shutting down plugin âINNODB_SYS_DATAFILESâ |
stdout |
2018-10-08 10:17:37 1 [Note] Shutting down plugin âPERFORMANCE_SCHEMAâ |
stdout |
2018-10-08 10:17:37 1 [Note] Shutting down plugin âpartitionâ |
stdout |
2018-10-08 10:17:37 1 [Note] Binlog end |
stdout |
2018-10-08 10:17:37 1 [Note] Forcefully disconnecting 0 remaining clients |
stdout |
2018-10-08 10:17:37 1 [Note] Shutting down slave threads |
stdout |
2018-10-08 10:17:37 1 [Note] Event Scheduler: Purging the queue. 0 events |
stdout |
2018-10-08 10:17:37 1 [Note] Giving 0 client threads a chance to die gracefully |
stdout |
stdout |
2018-10-08 10:17:37 1 [Note] mysqld: Normal shutdown |
| 2018-10-08 10:16:14 |
stdout |
stdout |
2018-10-08 10:16:14 1 [Note] mysqld: ready for connections. |
stdout |
2018-10-08 10:16:14 1 [Note] Event Scheduler: Loaded 0 events |
| 2018-10-08 10:16:13 |
stdout |
2018-10-08 10:16:13 1 [Warning] âproxies_privâ entry â@ root@cms-db2â ignored in --skip-name-resolve mode. |
stdout |
2018-10-08 10:16:13 1 [Note] Server socket created on IP: â::â. |
stdout |
2018-10-08 10:16:13 1 [Note] - â::â resolves to â::â; |
stdout |
2018-10-08 10:16:13 1 [Note] IPv6 is available. |
stdout |
2018-10-08 10:16:13 1 [Note] Server hostname (bind-address): â*â; port: 3306 |
stdout |
2018-10-08 10:16:13 1 [Note] InnoDB: 5.6.39 started; log sequence number 5230838672 |
stdout |
2018-10-08 10:16:13 1 [Note] InnoDB: Waiting for purge to start |
stdout |
2018-10-08 10:16:13 1 [Note] InnoDB: 128 rollback segment(s) are active. |
| 2018-10-08 10:16:12 |
stdout |
2018-10-08 10:16:12 1 [Note] InnoDB: Highest supported file format is Barracuda. |
stdout |
2018-10-08 10:16:12 1 [Note] InnoDB: Completed initialization of buffer pool |
stdout |
2018-10-08 10:16:12 1 [Note] InnoDB: Initializing buffer pool, size = 128.0M |
stdout |
2018-10-08 10:16:12 1 [Note] InnoDB: Using CPU crc32 instructions |
stdout |
2018-10-08 10:16:12 1 [Note] InnoDB: Using Linux native AIO |
stdout |
2018-10-08 10:16:12 1 [Note] InnoDB: Compressed tables use zlib 1.2.3 |
stdout |
2018-10-08 10:16:12 1 [Note] InnoDB: Memory barrier is not used |
stdout |
2018-10-08 10:16:12 1 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins |
stdout |
2018-10-08 10:16:12 1 [Note] InnoDB: The InnoDB memory heap is disabled |
stdout |
2018-10-08 10:16:12 1 [Note] InnoDB: Using atomics to ref count buffer pool pages |
stdout |
2018-10-08 10:16:12 1 [Note] Plugin âFEDERATEDâ is disabled. |
stdout |
2018-10-08 10:16:12 0 [Note] mysqld (mysqld 5.6.39) starting as process 1 ⌠|
stdout |
2018-10-08 10:16:12 0 [Warning] TIMESTAMP with implicit DEFAULT value is deprecated. Please use --explicit_defaults_for_timestamp server option (see documentation for more details). |
