Support for Flex Box in Xibo for Android
Does xibo for android (version 4) support Flex Box? If not, is there an alterative to achieve similar effects and functions with something else? The CMS is based also on Xibo version 4.
Thanks for help in advance.
Regards
Micke
I think Xibo Players work with internal navigator to show Web page.
On Android 9 with DSDevice 9X, flexbox works fine.
Hi
Could you please check which browser version i running on the DSDevice 9X? You can check that by making a layout with webpage widget pointed to https://www.whatsmybrowser.org/
Thanks in advance.
Regards
Micke
Operating System Android
Javascript enabled Yes
Cookies enabled Yes
Flash Version No installed
Java Version No Installed
Websockets support Yes
WebGL support Yes
Language fr-FR
Navigator size 1280 x 720
Screen size 1280 x 720 (Retina)
Color type 24 bit
AdBlock enabled No
user-agent :
Mozilla/5.0 (Linux; Android 9; DSCS9X Build/PPR1.180610.011; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/85.0.4183.81 Safari/537.36
Check this post : Change default browser
