Background:
I’m looking to install Xibo via docker on our CentOS VPS with a remote DB so we can easily query data from the Xibo DB and join data with our web application DB for integration and reporting purposes. The regular docker installation (with the integrated db container) works great, but I run into issues when bringing up the containers for a remote-db configuration.
Issue:
Starting with a clean docker environment, i.e., no other containers, when I attempt to bring up containers for a remote-db configuration, the process times out waiting for MySQL to start. Below is the message I get with IP masked out.
ERROR 2003 (HY000): Can’t connect to MySQL server on ‘xxx.xxx.xxx.xxx’ (110 “Operation timed out”)
I am confident the “MYSQL_” variables are set properly in my remote-config.env, because I can connect to the mysql db from other machines using the same info. The database does exist and is empty with the proper user permissions set up, etc.
I’m wondering if there is a network-related issue whereby the cms-web container is not able to route to my db. Perhaps I have a mis-configuration somewhere? I’ve tried changing the bind-address in the my.cnf file to 0.0.0.0 and I tried commenting it out. The result is the same.
My remote-docker-compose.yml seems pretty straightforward and is shown below. The only difference is I’m mapping to port 8080 for the web container.
Any assistance is greatly appreciated. Thanks in advance!
Update 2-6-2019:
I was tinkering with the remote-docker.yml file and added network_mode: host to each container. While this caused the web server to bomb (as expected), it did find and properly provision the external MySQL db which further indicates a networking/communication issue between the cms-web container and my db.
version: "2.1"
services:
cms-xmr:
image: xibosignage/xibo-xmr:release-0.7
ports:
- "9505:9505"
restart: always
env_file: remote-config.env
mem_limit: 256m
cms-web:
image: xibosignage/xibo-cms:release-1.8.12
volumes:
- "./shared/cms/custom:/var/www/cms/custom"
- "./shared/backup:/var/www/backup"
- "./shared/cms/web/theme/custom:/var/www/cms/web/theme/custom"
- "./shared/cms/library:/var/www/cms/library"
- "./shared/cms/web/userscripts:/var/www/cms/web/userscripts"
restart: always
links:
- cms-xmr:50001
environment:
- XMR_HOST=cms-xmr
ports:
- "8080:80"
mem_limit: 1g
