Installation Method
Docker on Unraid
Operating System
Unraid
I was able to successfully install Xibo on Unraid via Docker (Community Apps) but once I restarted the container it now gets stuck on “Running Maintenance”. I read that this could be caused by not properly configuring Xibo XMR. I didnt have Xibo XMR so I then installed it (also from Community Apps). Got the IP and port (192.168.50.103:9505) and restarted Xibo Docker again. Still the same error. Not sure what to do from here.
Here are the logs from Xibo…
cp: can't stat '/var/www/cms/ca-certs/*.pem': No such file or directory
cp: can't stat '/var/www/cms/ca-certs/*.crt': No such file or directory
WARNING: ca-certificates.crt does not contain exactly one certificate or CRL: skipping
crontab: can't open '/etc/crontabs/apache': Permission denied
Waiting for MySQL to start - max 300 seconds
MySQL started
DBVersion
146
Existing Database, checking if we need to upgrade it
Updating settings.php
Importing ca-certs
Configuring Maintenance
Removing web/install/index.php from production container
Running maintenance
MySQL started
DBVersion
146
Running maintenance
MySQL started
DBVersion
146
Running maintenance
