Hi again Alex,
The third error shows “Unable to get the media resource”
Surprisingly the layout has chosen to run this morning, but the status page still shows 1 file to download. How would I tell which file it is? The status screen shows resource 28 at 0% but I can’t see what resource 28 is, the library on the server doesn’t have a media item with an ID of 28. I have checked the local library and as far as I can tell everything is there. Background is there, all 3 tickers have a html file, both videos are there the clock has a flash object and a html the only other bit the layout plays is a webpage from our local intranet.
This seems to happen quite a lot when I update a video, maybe I’m doing it wrong. The process I use is open the media library on the server, click edit on the video I want to update, input the new duration (length of the video in seconds) in the duration box, make sure the “replace media tick box is checked”, click replace, upload the new file, click done when the upload is complete.
Should I be worrying about the duration field on the first page or does xibo sort this out itself.
The videos on the layout design have the “set duration” tickbox unchecked.
On a side note I am always getting the same 3 errors on the log in the CMS
2274914 7fff206 2017-10-19 08:02 XMDS POST ERROR DISPLAY GetResource Unknown error during getResource. E =
2274913 7fff206 2017-10-19 08:02 XMDS POST ERROR DISPLAY GetResource Request failed for dataSet id=0. Widget=28. Due to No Records Found
2274912 7fff206 2017-10-19 08:02 XMDS POST ERROR DISPLAY GetResource Unable to get feed: Unable to resolve hostname
I’m guessing widget 28 is the missing one. The status in the layout list has an exclamation saying "There are items on this layout that can only be accessed by the display.
So after some digging I found a ticker in a region that was pointing to display a category feed from a blog which was currently empty. Deleted the region and now I’m getting…
and
2275166 7e5130a 2017-10-19 08:18 PLAYER POST ERROR DISPLAY [FileAgent_resource_Id_28] FileAgent - Run Exception in Run: Requested an invalid file.
in the log.
Sorry for the long post, just want to get all the issues ironed out and really make a go of using it properly.
