Im seeing weird dates and times after a xibo upgrade from 1.7.9 to 1.8.1(Docker).
Heres is a screenshoot.
It fully shows as “2017201720172017-December-3131 1212”
Im seeing this in all date fields (tasks, schedule, etc)
Thanks in advance!
Thanks in advance!
Navigate to Settings -> Regional tab
At a guess your date format is, odd, you probably were using international dates with YYYY-MM-dd HH:mm:ss date format or something similar (in 1.7.9).
You could try and change it to the default Y-m-d H:i
or d-m-Y H:i
if that’s better for you.
OMG I just didnt think about doing it.
This is what I had: YYYY-MM-dd HH:mm:ss
Thank you very much!
