Hi
What are the system requirements needed to install the server software??
Thanks for your message. The system requirements will vary depending on your Xibo setup but you will find that the Docker based Ubuntu install guide uses a minimum of 2GB or RAM and 2GB of swap files. With this in mind, I would recommend at least 2GB of RAM minimum for your CMS setup but this may need to increase in the future depending on how your Xibo signage grows.
The Docker based installation method is recommended, I have provided a link to the Installation Guide pages for more information.
https://xibo.org.uk/docs/setup/cms-installation-guides
