Set Media Library as Homepage
Hi, how can I set the media page as homepage?
Which function can I modify?
Thanks a lot!
The homepage can be set on a per-user basis by editing their respective entries. There is no current method for setting a default homepage for newly-created users unless you are authenticating via an external SAML server.
When you add a new user or edit existing user you can select the homepage.
in 1.7.9 it’s only between status, icon and media dashboard
In 1.8 any CMS page can be set as a homepage.
Hi, thanks for your answer :slight_smile:.
Anyway there will be an part of code that I can hack or just add a tiny js to make it possible, am I wrong?
