Hi! Is it possible to have the box “set a duration” checked as default for every new uploaded image within a layout? I´m using 1.8.11 (windows 10).
Best regards
Gerald
It is not possible to have the Set a Duration box checked automatically.
If you would like to change the default duration for all images added to an Image Widget, you can adjust this in the Modules option of your CMS. Select the down facing arrow at the end of the Image Widget row, and choose Edit from the menu. You will see the option to set the Default Duration for all images uploaded to a layout.
