Second Instance of Xibo Player Client not working
Hello Team,
I’m having Two Monitor (1. HDMI->19201080, 2. VGA->1366768) and installed two instance of XIBO CLIENT PLAYER on same macnine. I have configure Second Screen profile as said . But if one instance of client is running then 2nd instance runs for a second and closed immediately.
you can find attached screen shot on below link
Successfully configured on Two Different Monitor.
Done . :slight_smile:
Could you solve it? I have the same problem. Thank you
Yes sure, will share video or steps to be followed.
