Hello!
Could you please help me: I got couple of text objects, a simple string, and I’m trying to put them rotating using Marquee Left scroll without duration, to run each only once. But the text doesn’t fully scrolling, it just cutting and rotating to next object on timeline.
I believe it using some default region duration of 5 secs.
How can I adjust these settings so each text string will show fully and then switch to another object on the region timeline?
Thank you!
You will need to adjust the Duration and possibly the Speed of the effect to ensure the entire message is Displayed before the next item.
You can adjust the Duration and speed by Editing the Text Widgets and selecting the Options tab. The Speed and Duration best suited for your scrolling text will depend on the length of the string and how fast you would like the text to scroll.
