First I want to thank you immensely for all the work you have done. Xibo is really a great platform.
Now we have a little problem and we hope you guys can help us.
As Secundary school we want to show our schedule information to our students. Therefore we have created a website that automatically scrolls. When we open this website in Google Chrome for example, everything goes well.
If we link this page to Xibo player the page is scrolling enormous slowly. Do you have an idea wat is going wrong?
Could you please tell us what CMS and player version are you using?
It would be also good to make sure you have IE11 installed and that you have correct registry entries for browser emulation in the correct path in your machine - Enabling HTML5 in the Windows .net Player
Thanks for the Rapid Response.
We use CMS version 1.7.4 for the player we use version 1.7.9 and Internet Explorer 11 is also installed.
Furthermore, I just checked the registry adjustments and those seem correct.
So I’m afraid it is not the solution for our problem.
Now we have performed the function of scrolling completely failed the CMS 1.7.9 update.
In Internet Exlorer everything seems to work fine, and of course the community website is also great to see the Xibo player.
For me it does look more sluggish in IE than let’s say chrome.
In Xibo it seems to be pretty much the same as in IE - at least on my work laptop
Still I wouldn’t say that it’s enormously slow, but it does not look great in IE, while it does in chrome, perhaps there are some adjustments that can be made to the website to make it run smoother in IE, and by extension in Xibo?
The scrolling speed is not well within Internet Explorer, Google Chrome has no problems. Is it possible to change the basic web browser to Google Chrome?
