Screen Resolution
Hi everybody,
I have screen in 4096x2160 and when i want to see my planning xibo change my resolution, so the screen is bad quality…
Someone can help me?
You’d need to use 4k UHD Landscape resolution on your layout, the content would need to be in similar quality (if it’s meant to be full screen) and the player connected to the screen must be capable of outputting such resolution.
If everything (layout, screen, player) resolution matches then it should display it correctly.
