Ok, here’s the log file:
Environment Checks
Item |
Status |
Advice |
PHP Version |
PHP version 5.3.3 or later required. Detected 5.5.38 |
File System Permissions |
Write access required for settings.php and install.php |
MySQL database (PHP MySql) |
MySQL support must be enabled in PHP. |
MySQL database (PDO MySql) |
PDO support with MySQL drivers must be enabled in PHP. |
JSON Extension |
PHP JSON extension required to function. |
SOAP Extension |
PHP SOAP extension required to function. |
GD Extension |
PHP GD extension to function. |
Session |
PHP session support to function. |
FileInfo |
Requires PHP FileInfo support to function. If you are on Windows you need to enable the php_fileinfo.dll in your php.ini file. |
PCRE |
PHP PCRE support to function. |
Gettext |
PHP Gettext support to function. |
Calendar Extension |
PHP Calendar extension to function. |
DOM Extension |
PHP DOM core functionality enabled. |
DOM XML Extension |
PHP DOM XML extension to function. |
Mcrypt Extension |
PHP Mcrypt extension to function. |
Allow PHP to open external URLs |
You must have allow_url_fopen = On in your PHP.ini file for RSS Feeds / Anonymous statistics gathering to function. |
DateTimeZone |
This enables us to get a list of time zones supported by the hosting server. |
ZIP |
This enables import / export of layouts. |
Large File Uploads |
Support for uploading large files is recommended. |
Internationalization |
International Support for formatting Dates, Numbers, etc. |
cURL |
cURL is used to fetch data from the Internet or Local Network |
LOG Dump
Date,Page,Function,Message
Display Dump
DisplayID: 2
Display: DAWSON2NDCP1
Default Layout: 169
Logged In: 0
Last Accessed: 1473969879
Interleave: 0
Licensed: 1
DisplayID: 3
Display: PC43
Default Layout: 0
Logged In: 1
Last Accessed: 1475603939
Interleave: 0
Licensed: 1
Settings Dump
Setting: MEDIA_DEFAULT - Value: private
Setting: LAYOUT_DEFAULT - Value: private
Setting: defaultUsertype - Value: User
Setting: userModule - Value: module_user_general.php
Setting: defaultTimezone - Value: Africa/Abidjan
Setting: mail_to - Value: mt@uga.edu
Setting: mail_from - Value: xibo@fcs.uga.edu
Setting: jpg_length - Value: 10
Setting: ppt_length - Value: 10
Setting: swf_length - Value: 10
Setting: audit - Value: audit
Setting: LIBRARY_LOCATION - Value: /xibo-library/
Setting: HELP_BASE - Value: Xibo User Manual | Xibo Digital Signage
Setting: PHONE_HOME - Value: On
Setting: PHONE_HOME_URL - Value: http://www.xibo.org.uk/stats/track.php
Setting: PHONE_HOME_DATE - Value: 1475161032
Setting: SERVER_MODE - Value: Production
Setting: MAINTENANCE_ENABLED - Value: Off
Setting: MAINTENANCE_EMAIL_ALERTS - Value: On
Setting: MAINTENANCE_KEY - Value: changeme
Setting: MAINTENANCE_LOG_MAXAGE - Value: 30
Setting: MAINTENANCE_STAT_MAXAGE - Value: 30
Setting: MAINTENANCE_ALERT_TOUT - Value: 12
Setting: SHOW_DISPLAY_AS_VNCLINK - Value:
Setting: SHOW_DISPLAY_AS_VNC_TGT - Value: _top
Setting: MAINTENANCE_ALWAYS_ALERT - Value: Off
Setting: SCHEDULE_LOOKAHEAD - Value: On
Setting: REQUIRED_FILES_LOOKAHEAD - Value: 172800
Setting: REGION_OPTIONS_COLOURING - Value: Media Colouring
Setting: LAYOUT_COPY_MEDIA_CHECKB - Value: Unchecked
Setting: MAX_LICENSED_DISPLAYS - Value: 0
Setting: LIBRARY_MEDIA_UPDATEINALL_CHECKB - Value: Unchecked
Setting: USER_PASSWORD_POLICY - Value:
Setting: USER_PASSWORD_ERROR - Value:
Setting: MODULE_CONFIG_LOCKED_CHECKB - Value: Unchecked
Setting: LIBRARY_SIZE_LIMIT_KB - Value: 0
Setting: MONTHLY_XMDS_TRANSFER_LIMIT_KB - Value: 0
Setting: DEFAULT_LANGUAGE - Value: en_GB
Setting: TRANSITION_CONFIG_LOCKED_CHECKB - Value: Unchecked
Setting: GLOBAL_THEME_NAME - Value: default
Setting: DEFAULT_LAT - Value: 51.504
Setting: DEFAULT_LONG - Value: -0.104
Setting: SCHEDULE_WITH_VIEW_PERMISSION - Value: No
Setting: SETTING_IMPORT_ENABLED - Value: 1
Setting: SETTING_LIBRARY_TIDY_ENABLED - Value: 1
Setting: SENDFILE_MODE - Value: Off
Setting: EMBEDDED_STATUS_WIDGET - Value:
Setting: PROXY_HOST - Value:
Setting: PROXY_PORT - Value: 0
Setting: PROXY_AUTH - Value:
Setting: DATE_FORMAT - Value: Y-m-d H:i
Setting: DETECT_LANGUAGE - Value: 1
Setting: DEFAULTS_IMPORTED - Value: 1
Setting: FORCE_HTTPS - Value: 0
Setting: ISSUE_STS - Value: 0
Setting: STS_TTL - Value: 600
Setting: MAINTENANCE_ALERTS_FOR_VIEW_USERS - Value: 0
Setting: CALENDAR_TYPE - Value: Gregorian
Setting: DASHBOARD_LATEST_NEWS_ENABLED - Value: 1
Setting: LIBRARY_MEDIA_DELETEOLDVER_CHECKB - Value: Unchecked
Setting: USE_INTL_DATEFORMAT - Value: 0
Setting: PROXY_EXCEPTIONS - Value:
Setting: CDN_URL - Value:
Sessions Dump
UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64; rv:49.0) Gecko/20100101 Firefox/49.0
RemoteAddress: 128.192.32.240
Session Data
pagename|s:5:"admin";token|s:32:"71bce6ac12949492f39554bbff78a044";token_timeout|i:1475603912;message|s:0:"";userid|s:1:"3";username|s:4:"mark";usertype|s:1:"1";DisplayGroupIDs|a:1:{i:0;s:2:"12";}57f3ea9608dde|s:32:"23998c273b58fdf13cf0accb9bf5fc98";57f3ea9608dde_timeout|i:1475603094;
Mark Toomey, Systems and Network Manager
Family and Consumer Sciences, UGA
mark at fcs dot uga dot edu: GChat: mark@toominator.netmailto:mark@toominator.net
Owner: USG-TECH, USG-VM, HT, COOLTECH,& UGASTUFF Lists
voice:706-542-4738 - cell:706-255-8683 - fax:706-542-4168
Linux: The Power of Choice
