I am currently trying to run a new layout for this week, 2/3 have accepted this change. The Xibo on application is running and on the screen but is not displaying the layout.
I have deleted the schedule and started from scratch in case I missed anything, still nothing loads up on the computer Xibo.
Could you please, close the player, open Xibo Player Options (where you enter the CMS address / key), click Save and show/tell me what it says there?
^ If you will post images of that form, please make sure to not show your CMS Address/key there, especially if it’s available over the internet.
If you have just one player and that player shows as authorised in the CMS, then perhaps the hardwarekey changed from what it’s stored in CMS database ie when you connect the player now it would create a new display record.
If it is a player that was already connected to your CMS, then you can ensure that the hardwarekye in CMS is the same as the one on the player - you can change hardwarekey in the Xibo Player Options -> Advanced tab -> Display ID
Thank you for the screenshot. As the Player was connected previously, you have 2 options on how to proceed:
You can click the Advanced tab in shown in the below screenshot and add any letter to the end of the Display ID. Once you have done this, click Save. This will cause a new Display entry to appear in the Displays section of your CMS, which you can then Authorise.
If you still have the original entry for this Player in the Displays section of your CMS, you can click the down facing triangle at the end of that entry and choose Edit from the drop down. You will see under the General tab there is a field named Hardware Key. You will need to make sure this Hardware key matches the Display ID in the Player Options, then save.
