Schedule Layouts/Campaigns Not Working
Need some help with a new installation of Xibo. Xibo installed on Server 2012 r2 using XAMPP and Windows Client on WIN 10, latest version available to download for both server and client.
I’ve rebuilt the server a few times and client but no success. I am able to show the default layout with nothing scheduled, I then copy the default layout and change the background color and just the text and use that as my 2nd layout.
I’ve tried to schedule the 2nd layout i’ve created by schedule now, I see the device status go into an explanation mark and then check mark. I’ve set up the windows profile to download every minute as part of troubleshooting. Also tried scheduling now through campaign and still no luck.
If I set the default layout to the one I’ve create it shows up on the device… But if I go back to the out of the box default layout and then schedule my layout it doesn’t show at all.
Any ideas?
hmm I’d say check CMS / server date/time and your device date/time.
You can also show us a screenshot of status window on your device - press ‘i’ on your keyboard to show it while Xibo for Windows is focused.
Yes verified time is correct on both the server and client. They’re both also joined to the domain
Here is a screenshot of the client. Looks like layout is no good? But it works if I set it as default and it have the check mark next to it when its in layout
So as far as player is concerned it did download layout 6 (presumably when it was set as a default layout).
It seems to be currently displaying layout 5 and that looks ok to me, although if you did schedule layout 6 to be displayed then player should have it under ‘Schedule Status’.
Could you perhaps create a new layout, something very simple, add some text perhaps some image to it.
Schedule it to display on your device, make sure the ‘collection interval’ has passed / restart your device ie that your player should know about this scheduled event.
// You can adjust collection interval on Display settings page -> edit display profile assigned to your device
Then if that does not work, please show us a screenshot of status window again.
i’ve been trying that for a bit. This is the current layout that i’ve copied off the out of box default and it won’t run when scheduled. But runs when I set it as default.
I’ve set the windows profile to collect every minute for testing.
Its been set this way prior to this case being opened.
Any updates on this issue?
Could you please
Enable debugging on Report Fault page
Enable Auditing on your display (Displays page -> edit your display -> advanced tab)
Recreate the issue, make sure player is connected to the CMS/internet so it does send logs to it.
Then on report fault page click the collect and save data button, that will download logs to troubleshoot.txt file.
Once you got that file please send it to me, here or via pm.
That file might contain some sensitive data about your Device / CMS please make sure to edit it before posting it publicly here.
Peter, sorry for the late response, don’t know how to PM you as I don’t see that as an option so i’ll paste the text here
Environment Checks
Item Status Advice
PHP Version PHP version 5.3.3 or later required. Detected 5.6.23
File System Permissions Write access required for settings.php and install.php
MySQL database (PHP MySql) MySQL support must be enabled in PHP.
MySQL database (PDO MySql) PDO support with MySQL drivers must be enabled in PHP.
JSON Extension PHP JSON extension required to function.
SOAP Extension PHP SOAP extension required to function.
GD Extension PHP GD extension to function.
Session PHP session support to function.
FileInfo Requires PHP FileInfo support to function. If you are on Windows you need to enable the php_fileinfo.dll in your php.ini file.
PCRE PHP PCRE support to function.
Gettext PHP Gettext support to function.
Calendar Extension PHP Calendar extension to function.
DOM Extension PHP DOM core functionality enabled.
DOM XML Extension PHP DOM XML extension to function.
Mcrypt Extension PHP Mcrypt extension to function.
Allow PHP to open external URLs You must have allow_url_fopen = On in your PHP.ini file for RSS Feeds / Anonymous statistics gathering to function.
DateTimeZone This enables us to get a list of time zones supported by the hosting server.
ZIP This enables import / export of layouts.
Large File Uploads Support for uploading large files is recommended.
Internationalization International Support for formatting Dates, Numbers, etc.Translations will still function without this PHP module, however dates, times and numbers will not be shown in your locale.
cURL cURL is used to fetch data from the Internet or Local Network
LOG Dump
Date,Page,Function,Message
"2016-11-15 22:28:58",“XMDSSoap4”,“RegisterDisplay”,"serverKey: REMOVED, hardwareKey: REMOVED, displayName: WAREHOUSETV1"
“2016-11-15 22:28:58”,“DisplayProfile”,“LoadDefault”,“Load Default windows”
“2016-11-15 22:28:58”,“Display”,“Touch”,“IN”
“2016-11-15 22:28:58”,“XMDSSoap4”,“RegisterDisplay”,"<?xml version="1.0"?>
600010000010IBottom Right110001audit200031WAREHOUSETV10
“2016-11-15 22:28:15”,“XMDSSoap4”,“Schedule”,"FromDT = 2016-11-15 10:00:00. ToDt = 2016-11-17 11:00:00"
“2016-11-15 22:28:15”,“XMDSSoap4”,“Schedule”,“<?xml version="1.0"?>
jquery-1.11.1.min.js
xibo-layout-scaler.js
xibo-webpage-render.js
moment.js
jquery.marquee.min.js
jquery-cycle-2.1.6.min.js
xibo-text-render.js
xibo-dataset-render.js
flipclock.min.js
“2016-11-15 22:28:15”,“XMDSSoap4”,“Schedule”,“Schedule not in Cache 2. Will cache and expire after 174705"
“2016-11-15 22:28:05”,“XMDSSoap4”,“NotifyStatus”,”{“availableSpace”:“182327193600”, “totalSpace”:“234287714304”}"
“2016-11-15 22:28:05”,“Display”,“Touch”,“IN”
“2016-11-15 22:28:05”,“XMDSSoap4”,“SubmitLog”,“XML log: 11/15/2016 11:26:17 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:26:22 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:26:22 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:26:22 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(1365,665,0,0,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:26:22 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:26:22 AMUI ThreadMainForm - DurationElapsedEventAll Regions have expired. Raising a Next layout event.11/15/2016 11:26:22 AMUI ThreadMainForm - ScheduleChangeEventSchedule Changing to C:\Users\jlau\Documents\Xibo Library\5.xlf11/15/2016 11:26:22 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 47ff29524ce1b11/15/2016 11:26:22 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 53654d56726e011/15/2016 11:26:23 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:26:23 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 522caef6e13cb6c9fe5fac15dde59ef711/15/2016 11:26:23 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:26:24 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:26:24 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 11846d5d9f686fb75fc9dad0b19ca9de11/15/2016 11:26:24 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:26:26 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:26:26 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:26:34 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:26:34 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:26:34 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(307,91,669,1045,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:26:34 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:26:34 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:26:36 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:26:36 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:26:39 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:26:39 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:26:39 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(1365,665,0,0,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:26:39 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:26:39 AMUI ThreadMainForm - DurationElapsedEventAll Regions have expired. Raising a Next layout event.11/15/2016 11:26:39 AMUI ThreadMainForm - ScheduleChangeEventSchedule Changing to C:\Users\jlau\Documents\Xibo Library\5.xlf11/15/2016 11:26:39 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 47ff29524ce1b11/15/2016 11:26:39 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 53654d56726e011/15/2016 11:26:40 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:26:40 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 522caef6e13cb6c9fe5fac15dde59ef711/15/2016 11:26:40 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:26:41 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:26:41 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 11846d5d9f686fb75fc9dad0b19ca9de11/15/2016 11:26:41 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:26:46 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:26:46 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:26:51 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:26:51 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:26:51 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(307,91,669,1045,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:26:51 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:26:51 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:26:56 AMRegisterAgentThreadRegisterAgent - RunThread Woken and Lock Obtained11/15/2016 11:26:56 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:26:56 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:26:56 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:26:56 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:26:56 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(1365,665,0,0,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:26:56 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:26:56 AMUI ThreadMainForm - DurationElapsedEventAll Regions have expired. Raising a Next layout event.11/15/2016 11:26:56 AMUI ThreadMainForm - ScheduleChangeEventSchedule Changing to C:\Users\jlau\Documents\Xibo Library\5.xlf11/15/2016 11:26:56 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 47ff29524ce1b11/15/2016 11:26:56 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 53654d56726e011/15/2016 11:26:57 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:26:57 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 522caef6e13cb6c9fe5fac15dde59ef711/15/2016 11:26:57 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:26:58 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:26:58 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 11846d5d9f686fb75fc9dad0b19ca9de11/15/2016 11:26:58 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:27:01 AMRequiredFilesAgentThreadRequiredFiles - ReportInventoryReporting Inventory11/15/2016 11:27:03 AMLogAgentRegisterAgent - RunThread Woken and Lock Obtained11/15/2016 11:27:06 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:27:06 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:27:08 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:27:08 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:27:08 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(307,91,669,1045,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:27:08 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:27:08 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:27:13 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:27:13 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:27:13 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(1365,665,0,0,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:27:13 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:27:13 AMUI ThreadMainForm - DurationElapsedEventAll Regions have expired. Raising a Next layout event.11/15/2016 11:27:13 AMUI ThreadMainForm - ScheduleChangeEventSchedule Changing to C:\Users\jlau\Documents\Xibo Library\5.xlf11/15/2016 11:27:13 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 47ff29524ce1b11/15/2016 11:27:13 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 53654d56726e011/15/2016 11:27:14 AMScheduleAgentThreadScheduleAgent - RunThread Woken and Lock Obtained11/15/2016 11:27:14 AMScheduleAgentThreadScheduleManager - GetScheduleXmlStringGetting the Schedule XML11/15/2016 11:27:14 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:27:14 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 522caef6e13cb6c9fe5fac15dde59ef711/15/2016 11:27:14 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:27:15 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:27:15 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 11846d5d9f686fb75fc9dad0b19ca9de11/15/2016 11:27:15 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:27:16 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:27:16 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:27:25 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:27:25 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:27:25 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(307,91,669,1045,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:27:25 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:27:25 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:27:26 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:27:26 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:27:30 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:27:30 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:27:30 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(1365,665,0,0,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:27:30 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:27:30 AMUI ThreadMainForm - DurationElapsedEventAll Regions have expired. Raising a Next layout event.”
“2016-11-15 22:28:04”,“XMDSSoap4”,“MediaInventory”,""
“2016-11-15 22:28:04”,“Display”,“Touch”,“IN”
“2016-11-15 22:28:03”,“XMDSSoap4”,“RequiredFiles”,“hardwareKey = REMOVED”
“2016-11-15 22:28:03”,“XMDSSoap4”,“RequiredFiles”,“Required files date criteria. FromDT = 2016-11-15 10:00:00. ToDt = 2016-11-17 11:00:00"
“2016-11-15 22:28:03”,“XMDSSoap4”,“RequiredFiles”,“MD5 for layoutId 5 is: [7660f3ceabacdd9e50119290565241d1]”
“2016-11-15 22:28:03”,“XMDSSoap4”,“RequiredFiles”,“MD5 for layoutId 7 is: [3f42f0cef4103612d6e12d65a61f4b37]”
“2016-11-15 22:28:03”,“layout”,“LayoutInformation”,”[IN]"
“2016-11-15 22:28:03”,“Layout”,“GetLayoutXml”,“IN”
“2016-11-15 22:28:03”,“Layout”,“GetLayoutXml”,“OUT”
“2016-11-15 22:28:03”,“layout”,“SetDomXML”,“Loading LayoutXml into the DOM”
“2016-11-15 22:28:03”,“layout”,“SetDomXML”,“Loaded LayoutXml into the DOM”
“2016-11-15 22:28:03”,“layout”,“GetRegionList”,"[IN] Loaded XML into DOM"
“2016-11-15 22:28:03”,“layout”,“GetRegionList”,"[OUT]"
“2016-11-15 22:28:03”,“layout”,“LayoutInformation”,“Assessing Region: 47ff29524ce1b”
“2016-11-15 22:28:03”,“layout”,“LayoutInformation”,“Finished with Region”
“2016-11-15 22:28:03”,“layout”,“LayoutInformation”,“Assessing Region: 53654d56726e0"
“2016-11-15 22:28:03”,“XMDSSoap4”,“RequiredFiles”,”<?xml version="1.0"?>
“2016-11-15 22:27:57”,“XMDSSoap4”,“RegisterDisplay”,“serverKey: REMOVED, hardwareKey: REMOVED, displayName: WAREHOUSETV1"
“2016-11-15 22:27:57”,“DisplayProfile”,“LoadDefault”,“Load Default windows”
“2016-11-15 22:27:57”,“Display”,“Touch”,“IN”
“2016-11-15 22:27:57”,“XMDSSoap4”,“RegisterDisplay”,“<?xml version="1.0"?>
“2016-11-15 22:27:14”,“XMDSSoap4”,“Schedule”,“Returning schedule from Cache for display 2"
“2016-11-15 22:27:10”,“schedule”,””,“No display groups selected
256
User Error
C:\xampp\htdocs\xibo\lib\pages\schedule.class.php
968
“2016-11-15 22:27:05”,“schedule”,””,“No display groups selected
256
User Error
968
“2016-11-15 22:27:03”,“XMDSSoap4”,“MediaInventory”,””
“2016-11-15 22:27:03”,“Display”,“Touch”,“IN”
“2016-11-15 22:27:03”,“XMDSSoap4”,“NotifyStatus”,"{“availableSpace”:“182327259136”, “totalSpace”:“234287714304”}"
“2016-11-15 22:27:03”,“XMDSSoap4”,“SubmitLog”,“XML log: 11/15/2016 11:25:08 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:25:08 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:25:08 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(307,91,669,1045,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:25:08 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:25:08 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:25:13 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:25:13 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:25:13 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(1365,665,0,0,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:25:13 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:25:13 AMUI ThreadMainForm - DurationElapsedEventAll Regions have expired. Raising a Next layout event.11/15/2016 11:25:13 AMUI ThreadMainForm - ScheduleChangeEventSchedule Changing to C:\Users\jlau\Documents\Xibo Library\5.xlf11/15/2016 11:25:13 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 47ff29524ce1b11/15/2016 11:25:13 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 53654d56726e011/15/2016 11:25:14 AMScheduleAgentThreadScheduleAgent - RunThread Woken and Lock Obtained11/15/2016 11:25:14 AMScheduleAgentThreadScheduleManager - GetScheduleXmlStringGetting the Schedule XML11/15/2016 11:25:14 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:25:14 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 522caef6e13cb6c9fe5fac15dde59ef711/15/2016 11:25:14 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:25:15 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:25:15 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 11846d5d9f686fb75fc9dad0b19ca9de11/15/2016 11:25:15 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:25:16 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:25:16 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:25:25 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:25:25 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:25:25 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(307,91,669,1045,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:25:25 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:25:25 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:25:26 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:25:26 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:25:30 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:25:30 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:25:30 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(1365,665,0,0,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:25:30 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:25:30 AMUI ThreadMainForm - DurationElapsedEventAll Regions have expired. Raising a Next layout event.11/15/2016 11:25:30 AMUI ThreadMainForm - ScheduleChangeEventSchedule Changing to C:\Users\jlau\Documents\Xibo Library\5.xlf11/15/2016 11:25:30 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 47ff29524ce1b11/15/2016 11:25:30 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 53654d56726e011/15/2016 11:25:31 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:25:31 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 522caef6e13cb6c9fe5fac15dde59ef711/15/2016 11:25:31 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:25:32 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:25:32 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 11846d5d9f686fb75fc9dad0b19ca9de11/15/2016 11:25:32 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:25:36 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:25:36 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:25:43 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:25:43 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:25:43 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(307,91,669,1045,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:25:43 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:25:43 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:25:46 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:25:46 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:25:47 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:25:47 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:25:47 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(1365,665,0,0,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:25:47 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:25:47 AMUI ThreadMainForm - DurationElapsedEventAll Regions have expired. Raising a Next layout event.11/15/2016 11:25:47 AMUI ThreadMainForm - ScheduleChangeEventSchedule Changing to C:\Users\jlau\Documents\Xibo Library\5.xlf11/15/2016 11:25:47 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 47ff29524ce1b11/15/2016 11:25:47 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 53654d56726e011/15/2016 11:25:48 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:25:48 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 522caef6e13cb6c9fe5fac15dde59ef711/15/2016 11:25:48 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:25:49 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:25:49 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 11846d5d9f686fb75fc9dad0b19ca9de11/15/2016 11:25:49 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:25:55 AMRegisterAgentThreadRegisterAgent - RunThread Woken and Lock Obtained11/15/2016 11:25:56 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:25:56 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:26:00 AMRequiredFilesAgentThreadRequiredFiles - ReportInventoryReporting Inventory11/15/2016 11:26:00 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:26:00 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:26:00 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(307,91,669,1045,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:26:00 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:26:00 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:26:01 AMLogAgentRegisterAgent - RunThread Woken and Lock Obtained11/15/2016 11:26:05 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:26:05 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:26:05 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(1365,665,0,0,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:26:05 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:26:05 AMUI ThreadMainForm - DurationElapsedEventAll Regions have expired. Raising a Next layout event.11/15/2016 11:26:05 AMUI ThreadMainForm - ScheduleChangeEventSchedule Changing to C:\Users\jlau\Documents\Xibo Library\5.xlf11/15/2016 11:26:05 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 47ff29524ce1b11/15/2016 11:26:05 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 53654d56726e011/15/2016 11:26:06 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:26:06 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 522caef6e13cb6c9fe5fac15dde59ef711/15/2016 11:26:06 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:26:06 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:26:06 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:26:07 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:26:07 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 11846d5d9f686fb75fc9dad0b19ca9de11/15/2016 11:26:07 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:26:14 AMScheduleAgentThreadScheduleAgent - RunThread Woken and Lock Obtained11/15/2016 11:26:14 AMScheduleAgentThreadScheduleManager - GetScheduleXmlStringGetting the Schedule XML11/15/2016 11:26:16 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:26:16 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:26:17 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:26:17 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:26:17 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(307,91,669,1045,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:26:17 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed”
“2016-11-15 22:27:02”,“XMDSSoap4”,“RequiredFiles”,“hardwareKey = REMOVED”
“2016-11-15 22:27:02”,“XMDSSoap4”,“RequiredFiles”,“Returning required files from Cache for display WAREHOUSETV1 key display/2/requiredFiles”
“2016-11-15 22:26:57”,“Display”,“Touch”,“IN”
“2016-11-15 22:26:57”,“XMDSSoap4”,“RegisterDisplay”,“<?xml version="1.0"?>
“2016-11-15 22:26:56”,“XMDSSoap4”,“RegisterDisplay”,“serverKey: REMOVED, hardwareKey: REMOVED, displayName: WAREHOUSETV1"
“2016-11-15 22:26:56”,“DisplayProfile”,“LoadDefault”,“Load Default windows”
“2016-11-15 22:26:14”,“XMDSSoap4”,“Schedule”,“Returning schedule from Cache for display 2"
“2016-11-15 22:26:02”,“XMDSSoap4”,“MediaInventory”,””
“2016-11-15 22:26:02”,“Display”,“Touch”,“IN”
“2016-11-15 22:26:02”,“XMDSSoap4”,“NotifyStatus”,"{“availableSpace”:“182327259136”, “totalSpace”:“234287714304”}"
“2016-11-15 22:26:01”,“XMDSSoap4”,“SubmitLog”,"XML log: 11/15/2016 11:23:50 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:23:53 AMRegisterAgentThreadRegisterAgent - RunThread Woken and Lock Obtained11/15/2016 11:23:56 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:23:56 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:23:57 AMRequiredFilesAgentThreadRequiredFiles - ReportInventoryReporting Inventory11/15/2016 11:23:58 AMLogAgentRegisterAgent - RunThread Woken and Lock Obtained11/15/2016 11:24:00 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:24:00 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:24:00 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(307,91,669,1045,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:24:00 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:24:00 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:24:05 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:24:05 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:24:05 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(1365,665,0,0,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:24:05 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:24:05 AMUI ThreadMainForm - DurationElapsedEventAll Regions have expired. Raising a Next layout event.11/15/2016 11:24:05 AMUI ThreadMainForm - ScheduleChangeEventSchedule Changing to C:\Users\jlau\Documents\Xibo Library\5.xlf11/15/2016 11:24:05 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 47ff29524ce1b11/15/2016 11:24:05 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 53654d56726e011/15/2016 11:24:06 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:24:06 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 522caef6e13cb6c9fe5fac15dde59ef711/15/2016 11:24:06 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:24:06 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:24:06 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:24:07 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:24:07 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 11846d5d9f686fb75fc9dad0b19ca9de11/15/2016 11:24:07 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:24:14 AMScheduleAgentThreadScheduleAgent - RunThread Woken and Lock Obtained11/15/2016 11:24:14 AMScheduleAgentThreadScheduleManager - GetScheduleXmlStringGetting the Schedule XML11/15/2016 11:24:16 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:24:16 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:24:17 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:24:17 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:24:17 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(307,91,669,1045,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:24:17 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:24:17 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:24:22 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:24:22 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:24:22 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(1365,665,0,0,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:24:22 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:24:22 AMUI ThreadMainForm - DurationElapsedEventAll Regions have expired. Raising a Next layout event.11/15/2016 11:24:22 AMUI ThreadMainForm - ScheduleChangeEventSchedule Changing to C:\Users\jlau\Documents\Xibo Library\5.xlf11/15/2016 11:24:22 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 47ff29524ce1b11/15/2016 11:24:22 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 53654d56726e011/15/2016 11:24:23 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:24:23 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 522caef6e13cb6c9fe5fac15dde59ef711/15/2016 11:24:23 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:24:24 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:24:24 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 11846d5d9f686fb75fc9dad0b19ca9de11/15/2016 11:24:24 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:24:26 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:24:26 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:24:34 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:24:34 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:24:34 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(307,91,669,1045,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:24:34 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:24:34 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:24:36 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:24:36 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:24:39 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:24:39 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:24:39 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(1365,665,0,0,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:24:39 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:24:39 AMUI ThreadMainForm - DurationElapsedEventAll Regions have expired. Raising a Next layout event.11/15/2016 11:24:39 AMUI ThreadMainForm - ScheduleChangeEventSchedule Changing to C:\Users\jlau\Documents\Xibo Library\5.xlf11/15/2016 11:24:39 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 47ff29524ce1b11/15/2016 11:24:39 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 53654d56726e011/15/2016 11:24:40 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:24:40 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 522caef6e13cb6c9fe5fac15dde59ef711/15/2016 11:24:40 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:24:41 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:24:41 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 11846d5d9f686fb75fc9dad0b19ca9de11/15/2016 11:24:41 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:24:46 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:24:46 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:24:51 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:24:51 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:24:51 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(307,91,669,1045,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:24:51 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:24:51 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:24:54 AMRegisterAgentThreadRegisterAgent - RunThread Woken and Lock Obtained11/15/2016 11:24:56 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:24:56 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:24:56 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:24:56 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:24:56 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(1365,665,0,0,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:24:56 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:24:56 AMUI ThreadMainForm - DurationElapsedEventAll Regions have expired. Raising a Next layout event.11/15/2016 11:24:56 AMUI ThreadMainForm - ScheduleChangeEventSchedule Changing to C:\Users\jlau\Documents\Xibo Library\5.xlf11/15/2016 11:24:56 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 47ff29524ce1b11/15/2016 11:24:56 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 53654d56726e011/15/2016 11:24:57 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:24:57 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 522caef6e13cb6c9fe5fac15dde59ef711/15/2016 11:24:57 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:24:58 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:24:58 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 11846d5d9f686fb75fc9dad0b19ca9de11/15/2016 11:24:58 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:24:58 AMRequiredFilesAgentThreadRequiredFiles - ReportInventoryReporting Inventory11/15/2016 11:25:00 AMLogAgentRegisterAgent - RunThread Woken and Lock Obtained11/15/2016 11:25:06 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:25:06 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: “
“2016-11-15 22:26:00”,“XMDSSoap4”,“RequiredFiles”,“hardwareKey = REMOVED”
“2016-11-15 22:26:00”,“XMDSSoap4”,“RequiredFiles”,“Returning required files from Cache for display WAREHOUSETV1 key display/2/requiredFiles”
“2016-11-15 22:25:56”,“XMDSSoap4”,“RegisterDisplay”,“serverKey: REMOVED, hardwareKey: REMOVED, displayName: WAREHOUSETV1"
“2016-11-15 22:25:56”,“DisplayProfile”,“LoadDefault”,“Load Default windows”
“2016-11-15 22:25:56”,“Display”,“Touch”,“IN”
“2016-11-15 22:25:56”,“XMDSSoap4”,“RegisterDisplay”,“<?xml version="1.0"?>
“2016-11-15 22:25:14”,“XMDSSoap4”,“Schedule”,“Returning schedule from Cache for display 2"
“2016-11-15 22:25:00”,“XMDSSoap4”,“MediaInventory”,””
“2016-11-15 22:25:00”,“Display”,“Touch”,“IN”
“2016-11-15 22:25:00”,“XMDSSoap4”,“NotifyStatus”,”{“availableSpace”:“182327283712”, “totalSpace”:“234287714304”}”
“2016-11-15 22:24:59”,“XMDSSoap4”,“RequiredFiles”,“hardwareKey = REMOVED”
“2016-11-15 22:24:59”,“XMDSSoap4”,“RequiredFiles”,“Returning required files from Cache for display WAREHOUSETV1 key display/2/requiredFiles”
“2016-11-15 22:24:55”,“Display”,“Touch”,“IN”
“2016-11-15 22:24:55”,“XMDSSoap4”,“RegisterDisplay”,“<?xml version="1.0"?>
“2016-11-15 22:24:54”,“XMDSSoap4”,“RegisterDisplay”,“serverKey: REMOVED, hardwareKey: REMOVED, displayName: WAREHOUSETV1"
“2016-11-15 22:24:54”,“DisplayProfile”,“LoadDefault”,“Load Default windows”
“2016-11-15 22:24:14”,“XMDSSoap4”,“Schedule”,“Returning schedule from Cache for display 2"
“2016-11-15 22:23:59”,“XMDSSoap4”,“MediaInventory”,””
“2016-11-15 22:23:59”,“Display”,“Touch”,“IN”
“2016-11-15 22:23:59”,“XMDSSoap4”,“NotifyStatus”,"{“availableSpace”:“182327001088”, “totalSpace”:“234287714304”}"
“2016-11-15 22:23:58”,“XMDSSoap4”,“SubmitLog”,“XML log: 11/15/2016 11:22:41 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:22:41 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 11846d5d9f686fb75fc9dad0b19ca9de11/15/2016 11:22:42 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:22:46 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:22:46 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:22:52 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:22:52 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:22:52 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(307,91,669,1045,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:22:52 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:22:52 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:22:52 AMRegisterAgentThreadRegisterAgent - RunThread Woken and Lock Obtained11/15/2016 11:22:56 AMRequiredFilesAgentThreadRequiredFiles - ReportInventoryReporting Inventory11/15/2016 11:22:56 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:22:56 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:22:56 AMLogAgentRegisterAgent - RunThread Woken and Lock Obtained11/15/2016 11:22:57 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:22:57 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:22:57 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(1365,665,0,0,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:22:57 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:22:57 AMUI ThreadMainForm - DurationElapsedEventAll Regions have expired. Raising a Next layout event.11/15/2016 11:22:57 AMUI ThreadMainForm - ScheduleChangeEventSchedule Changing to C:\Users\jlau\Documents\Xibo Library\5.xlf11/15/2016 11:22:57 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 47ff29524ce1b11/15/2016 11:22:57 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 53654d56726e011/15/2016 11:22:58 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:22:58 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 522caef6e13cb6c9fe5fac15dde59ef711/15/2016 11:22:58 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:22:58 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:22:58 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 11846d5d9f686fb75fc9dad0b19ca9de11/15/2016 11:22:58 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:23:06 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:23:06 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:23:07 AMLibraryAgentLibraryAgent - RunNumber of required files = 1511/15/2016 11:23:07 AMLibraryAgentLibraryAgent - RunDeleting old file: 250524b4c5ed8ffca9ccafdbcb8fa5c7.htm11/15/2016 11:23:07 AMLibraryAgentLibraryAgent - RunDeleting old file: 6.xlf11/15/2016 11:23:07 AMLibraryAgentLibraryAgent - RunDeleting old file: 8eaeaa7b78d74e32e5e611b3d7b94d61.htm11/15/2016 11:23:09 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:23:09 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:23:09 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(307,91,669,1045,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:23:09 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:23:09 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:23:14 AMScheduleAgentThreadScheduleAgent - RunThread Woken and Lock Obtained11/15/2016 11:23:14 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:23:14 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:23:14 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(1365,665,0,0,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:23:14 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:23:14 AMUI ThreadMainForm - DurationElapsedEventAll Regions have expired. Raising a Next layout event.11/15/2016 11:23:14 AMUI ThreadMainForm - ScheduleChangeEventSchedule Changing to C:\Users\jlau\Documents\Xibo Library\5.xlf11/15/2016 11:23:14 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 47ff29524ce1b11/15/2016 11:23:14 AMScheduleAgentThreadScheduleManager - GetScheduleXmlStringGetting the Schedule XML11/15/2016 11:23:14 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 53654d56726e011/15/2016 11:23:15 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:23:15 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 522caef6e13cb6c9fe5fac15dde59ef711/15/2016 11:23:15 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:23:15 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:23:15 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 11846d5d9f686fb75fc9dad0b19ca9de11/15/2016 11:23:15 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:23:16 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:23:16 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:23:26 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:23:26 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:23:26 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(307,91,669,1045,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:23:26 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:23:26 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:23:26 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:23:26 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:23:31 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:23:31 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:23:31 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(1365,665,0,0,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:23:31 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:23:31 AMUI ThreadMainForm - DurationElapsedEventAll Regions have expired. Raising a Next layout event.11/15/2016 11:23:31 AMUI ThreadMainForm - ScheduleChangeEventSchedule Changing to C:\Users\jlau\Documents\Xibo Library\5.xlf11/15/2016 11:23:31 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 47ff29524ce1b11/15/2016 11:23:31 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 53654d56726e011/15/2016 11:23:32 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:23:32 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 522caef6e13cb6c9fe5fac15dde59ef711/15/2016 11:23:32 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:23:33 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:23:33 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 11846d5d9f686fb75fc9dad0b19ca9de11/15/2016 11:23:33 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:23:36 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:23:36 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:23:43 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:23:43 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:23:43 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(307,91,669,1045,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:23:43 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:23:43 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:23:46 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:23:46 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:23:48 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:23:48 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:23:48 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(1365,665,0,0,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:23:48 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:23:48 AMUI ThreadMainForm - DurationElapsedEventAll Regions have expired. Raising a Next layout event.11/15/2016 11:23:48 AMUI ThreadMainForm - ScheduleChangeEventSchedule Changing to C:\Users\jlau\Documents\Xibo Library\5.xlf11/15/2016 11:23:48 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 47ff29524ce1b11/15/2016 11:23:48 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 53654d56726e011/15/2016 11:23:49 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:23:49 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 522caef6e13cb6c9fe5fac15dde59ef711/15/2016 11:23:49 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:23:50 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:23:50 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 11846d5d9f686fb75fc9dad0b19ca9de”
“2016-11-15 22:23:57”,“XMDSSoap4”,“RequiredFiles”,“hardwareKey = REMOVED”
“2016-11-15 22:23:57”,“XMDSSoap4”,“RequiredFiles”,“Returning required files from Cache for display WAREHOUSETV1 key display/2/requiredFiles”
“2016-11-15 22:23:54”,“XMDSSoap4”,“RegisterDisplay”,"serverKey: REMOVED, hardwareKey: REMOVED, displayName: WAREHOUSETV1"
“2016-11-15 22:23:54”,“DisplayProfile”,“LoadDefault”,“Load Default windows”
“2016-11-15 22:23:54”,“Display”,“Touch”,“IN”
“2016-11-15 22:23:54”,“XMDSSoap4”,“RegisterDisplay”,“<?xml version="1.0"?>
“2016-11-15 22:23:14”,“XMDSSoap4”,“Schedule”,“Returning schedule from Cache for display 2"
“2016-11-15 22:22:57”,“XMDSSoap4”,“SubmitLog”,“XML log: 11/15/2016 11:21:32 AMUI ThreadMainForm - ScheduleChangeEventSchedule Changing to C:\Users\jlau\Documents\Xibo Library\5.xlf11/15/2016 11:21:32 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 47ff29524ce1b11/15/2016 11:21:32 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 53654d56726e011/15/2016 11:21:33 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:21:33 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 522caef6e13cb6c9fe5fac15dde59ef711/15/2016 11:21:33 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:21:34 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:21:34 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 11846d5d9f686fb75fc9dad0b19ca9de11/15/2016 11:21:34 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:21:36 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:21:36 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:21:44 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:21:44 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:21:44 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(307,91,669,1045,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:21:44 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:21:44 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:21:46 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:21:46 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:21:49 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:21:49 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:21:49 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(1365,665,0,0,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:21:49 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:21:49 AMUI ThreadMainForm - DurationElapsedEventAll Regions have expired. Raising a Next layout event.11/15/2016 11:21:49 AMUI ThreadMainForm - ScheduleChangeEventSchedule Changing to C:\Users\jlau\Documents\Xibo Library\5.xlf11/15/2016 11:21:49 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 47ff29524ce1b11/15/2016 11:21:49 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 53654d56726e011/15/2016 11:21:50 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:21:50 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 522caef6e13cb6c9fe5fac15dde59ef711/15/2016 11:21:50 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:21:50 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:21:50 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 11846d5d9f686fb75fc9dad0b19ca9de11/15/2016 11:21:50 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:21:52 AMRegisterAgentThreadRegisterAgent - RunThread Woken and Lock Obtained11/15/2016 11:21:55 AMRequiredFilesAgentThreadRequiredFiles - ReportInventoryReporting Inventory11/15/2016 11:21:55 AMLogAgentRegisterAgent - RunThread Woken and Lock Obtained11/15/2016 11:21:56 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:21:56 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:22:01 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:22:01 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:22:01 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(307,91,669,1045,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:22:01 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:22:01 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:22:05 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:22:05 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:22:05 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(1365,665,0,0,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:22:05 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:22:05 AMUI ThreadMainForm - DurationElapsedEventAll Regions have expired. Raising a Next layout event.11/15/2016 11:22:05 AMUI ThreadMainForm - ScheduleChangeEventSchedule Changing to C:\Users\jlau\Documents\Xibo Library\5.xlf11/15/2016 11:22:05 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 47ff29524ce1b11/15/2016 11:22:06 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 53654d56726e011/15/2016 11:22:06 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:22:06 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:22:06 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:22:06 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 522caef6e13cb6c9fe5fac15dde59ef711/15/2016 11:22:06 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:22:07 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:22:07 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 11846d5d9f686fb75fc9dad0b19ca9de11/15/2016 11:22:07 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:22:14 AMScheduleAgentThreadScheduleAgent - RunThread Woken and Lock Obtained11/15/2016 11:22:14 AMScheduleAgentThreadScheduleManager - GetScheduleXmlStringGetting the Schedule XML11/15/2016 11:22:16 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:22:16 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:22:18 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:22:18 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:22:18 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(307,91,669,1045,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:22:18 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:22:18 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:22:23 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:22:23 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:22:23 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(1365,665,0,0,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:22:23 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:22:23 AMUI ThreadMainForm - DurationElapsedEventAll Regions have expired. Raising a Next layout event.11/15/2016 11:22:23 AMUI ThreadMainForm - ScheduleChangeEventSchedule Changing to C:\Users\jlau\Documents\Xibo Library\5.xlf11/15/2016 11:22:23 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 47ff29524ce1b11/15/2016 11:22:23 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 53654d56726e011/15/2016 11:22:23 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:22:23 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 522caef6e13cb6c9fe5fac15dde59ef711/15/2016 11:22:24 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:22:24 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:22:24 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 11846d5d9f686fb75fc9dad0b19ca9de11/15/2016 11:22:24 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:22:26 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:22:26 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:22:35 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:22:35 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:22:35 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(307,91,669,1045,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:22:35 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:22:35 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:22:36 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:22:36 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:22:40 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:22:40 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:22:40 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(1365,665,0,0,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:22:40 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:22:40 AMUI ThreadMainForm - DurationElapsedEventAll Regions have expired. Raising a Next layout event.11/15/2016 11:22:40 AMUI ThreadMainForm - ScheduleChangeEventSchedule Changing to C:\Users\jlau\Documents\Xibo Library\5.xlf11/15/2016 11:22:40 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 47ff29524ce1b11/15/2016 11:22:40 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 53654d56726e011/15/2016 11:22:41 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:22:41 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 522caef6e13cb6c9fe5fac15dde59ef711/15/2016 11:22:41 AMUI ThreadRegion - StartMediaStarting media”
“2016-11-15 22:22:57”,“XMDSSoap4”,“MediaInventory”,”"
“2016-11-15 22:22:57”,“Display”,“Touch”,“IN”
“2016-11-15 22:22:57”,“XMDSSoap4”,“NotifyStatus”,"{“availableSpace”:“182327070720”, “totalSpace”:“234287714304”}"
“2016-11-15 22:22:56”,“XMDSSoap4”,“RequiredFiles”,“hardwareKey = REMOVED”
“2016-11-15 22:22:56”,“XMDSSoap4”,“RequiredFiles”,“Returning required files from Cache for display WAREHOUSETV1 key display/2/requiredFiles”
“2016-11-15 22:22:53”,“XMDSSoap4”,“RegisterDisplay”,"serverKey: REMOVED, hardwareKey: REMOVED, displayName: WAREHOUSETV1"
“2016-11-15 22:22:53”,“DisplayProfile”,“LoadDefault”,“Load Default windows”
“2016-11-15 22:22:53”,“Display”,“Touch”,“IN”
“2016-11-15 22:22:53”,“XMDSSoap4”,“RegisterDisplay”,“<?xml version="1.0"?>
“2016-11-15 22:22:14”,“XMDSSoap4”,“Schedule”,“Returning schedule from Cache for display 2"
“2016-11-15 22:21:56”,“XMDSSoap4”,“MediaInventory”,”"
“2016-11-15 22:21:56”,“Display”,“Touch”,“IN”
“2016-11-15 22:21:56”,“XMDSSoap4”,“NotifyStatus”,"{“availableSpace”:“182327070720”, “totalSpace”:“234287714304”}"
“2016-11-15 22:21:55”,“XMDSSoap4”,“RequiredFiles”,“hardwareKey = REMOVED”
“2016-11-15 22:21:55”,“XMDSSoap4”,“RequiredFiles”,“Returning required files from Cache for display WAREHOUSETV1 key display/2/requiredFiles”
“2016-11-15 22:21:55”,“XMDSSoap4”,“SubmitLog”,“XML log: 11/15/2016 11:20:20 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:20:25 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:20:25 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:20:25 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(1365,665,0,0,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:20:25 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:20:25 AMUI ThreadMainForm - DurationElapsedEventAll Regions have expired. Raising a Next layout event.11/15/2016 11:20:25 AMUI ThreadMainForm - ScheduleChangeEventSchedule Changing to C:\Users\jlau\Documents\Xibo Library\5.xlf11/15/2016 11:20:25 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 47ff29524ce1b11/15/2016 11:20:25 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 53654d56726e011/15/2016 11:20:25 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:20:25 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 522caef6e13cb6c9fe5fac15dde59ef711/15/2016 11:20:26 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:20:26 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:20:26 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:20:26 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:20:26 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 11846d5d9f686fb75fc9dad0b19ca9de11/15/2016 11:20:27 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:20:36 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:20:36 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:20:37 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:20:37 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:20:37 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(307,91,669,1045,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:20:37 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:20:37 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:20:42 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:20:42 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:20:42 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(1365,665,0,0,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:20:42 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:20:42 AMUI ThreadMainForm - DurationElapsedEventAll Regions have expired. Raising a Next layout event.11/15/2016 11:20:42 AMUI ThreadMainForm - ScheduleChangeEventSchedule Changing to C:\Users\jlau\Documents\Xibo Library\5.xlf11/15/2016 11:20:42 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 47ff29524ce1b11/15/2016 11:20:42 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 53654d56726e011/15/2016 11:20:43 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:20:43 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 522caef6e13cb6c9fe5fac15dde59ef711/15/2016 11:20:43 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:20:43 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:20:43 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 11846d5d9f686fb75fc9dad0b19ca9de11/15/2016 11:20:43 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:20:46 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:20:46 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:20:51 AMRegisterAgentThreadRegisterAgent - RunThread Woken and Lock Obtained11/15/2016 11:20:54 AMLogAgentRegisterAgent - RunThread Woken and Lock Obtained11/15/2016 11:20:54 AMRequiredFilesAgentThreadRequiredFiles - ReportInventoryReporting Inventory11/15/2016 11:20:54 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:20:54 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:20:54 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(307,91,669,1045,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:20:54 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:20:54 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:20:56 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:20:56 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:20:59 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:20:59 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:20:59 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(1365,665,0,0,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:20:59 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:20:59 AMUI ThreadMainForm - DurationElapsedEventAll Regions have expired. Raising a Next layout event.11/15/2016 11:20:59 AMUI ThreadMainForm - ScheduleChangeEventSchedule Changing to C:\Users\jlau\Documents\Xibo Library\5.xlf11/15/2016 11:20:59 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 47ff29524ce1b11/15/2016 11:20:59 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 53654d56726e011/15/2016 11:21:00 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:21:00 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 522caef6e13cb6c9fe5fac15dde59ef711/15/2016 11:21:00 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:21:00 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:21:00 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 11846d5d9f686fb75fc9dad0b19ca9de11/15/2016 11:21:00 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:21:06 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:21:06 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:21:11 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:21:11 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:21:11 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(307,91,669,1045,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:21:11 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:21:11 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:21:13 AMScheduleAgentThreadScheduleAgent - RunThread Woken and Lock Obtained11/15/2016 11:21:14 AMScheduleAgentThreadScheduleManager - GetScheduleXmlStringGetting the Schedule XML11/15/2016 11:21:16 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:21:16 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:21:16 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(1365,665,0,0,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:21:16 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:21:16 AMUI ThreadMainForm - DurationElapsedEventAll Regions have expired. Raising a Next layout event.11/15/2016 11:21:16 AMUI ThreadMainForm - ScheduleChangeEventSchedule Changing to C:\Users\jlau\Documents\Xibo Library\5.xlf11/15/2016 11:21:16 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 47ff29524ce1b11/15/2016 11:21:16 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 53654d56726e011/15/2016 11:21:16 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:21:16 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:21:16 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:21:16 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 522caef6e13cb6c9fe5fac15dde59ef711/15/2016 11:21:17 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:21:17 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:21:17 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 11846d5d9f686fb75fc9dad0b19ca9de11/15/2016 11:21:17 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:21:26 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:21:26 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:21:27 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:21:27 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:21:27 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(307,91,669,1045,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:21:27 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:21:27 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:21:32 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:21:32 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:21:32 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(1365,665,0,0,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:21:32 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:21:32 AMUI ThreadMainForm - DurationElapsedEventAll Regions have expired. Raising a Next layout event.”
“2016-11-15 22:21:52”,“XMDSSoap4”,“RegisterDisplay”,"serverKey: REMOVED, hardwareKey: REMOVED, displayName: WAREHOUSETV1"
“2016-11-15 22:21:52”,“DisplayProfile”,“LoadDefault”,“Load Default windows”
“2016-11-15 22:21:52”,“Display”,“Touch”,“IN”
“2016-11-15 22:21:52”,“XMDSSoap4”,“RegisterDisplay”,“<?xml version="1.0"?>
600010000010IBottom Right110001audit200031WAREHOUSETV10
“2016-11-15 22:21:14”,“XMDSSoap4”,“Schedule”,“Returning schedule from Cache for display 2"
“2016-11-15 22:20:55”,“XMDSSoap4”,“MediaInventory”,”"
“2016-11-15 22:20:55”,“Display”,“Touch”,“IN”
“2016-11-15 22:20:55”,“XMDSSoap4”,“NotifyStatus”,"{“availableSpace”:“182327595008”, “totalSpace”:“234287714304”}"
“2016-11-15 22:20:54”,“XMDSSoap4”,“RequiredFiles”,“hardwareKey = REMOVED”
“2016-11-15 22:20:54”,“XMDSSoap4”,“RequiredFiles”,“Returning required files from Cache for display WAREHOUSETV1 key display/2/requiredFiles”
“2016-11-15 22:20:54”,“XMDSSoap4”,“SubmitLog”,“XML log: 11/15/2016 11:19:12 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:19:12 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:19:12 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(307,91,669,1045,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:19:12 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:19:12 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:19:13 AMScheduleAgentThreadScheduleAgent - RunThread Woken and Lock Obtained11/15/2016 11:19:13 AMScheduleAgentThreadScheduleManager - GetScheduleXmlStringGetting the Schedule XML11/15/2016 11:19:16 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:19:16 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:19:17 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:19:17 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:19:17 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(1365,665,0,0,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:19:17 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:19:17 AMUI ThreadMainForm - DurationElapsedEventAll Regions have expired. Raising a Next layout event.11/15/2016 11:19:17 AMUI ThreadMainForm - ScheduleChangeEventSchedule Changing to C:\Users\jlau\Documents\Xibo Library\5.xlf11/15/2016 11:19:17 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 47ff29524ce1b11/15/2016 11:19:17 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 53654d56726e011/15/2016 11:19:17 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:19:17 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 522caef6e13cb6c9fe5fac15dde59ef711/15/2016 11:19:17 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:19:18 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:19:18 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 11846d5d9f686fb75fc9dad0b19ca9de11/15/2016 11:19:18 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:19:26 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:19:26 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:19:29 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:19:29 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:19:29 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(307,91,669,1045,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:19:29 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:19:29 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:19:33 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:19:33 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:19:33 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(1365,665,0,0,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:19:33 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:19:33 AMUI ThreadMainForm - DurationElapsedEventAll Regions have expired. Raising a Next layout event.11/15/2016 11:19:33 AMUI ThreadMainForm - ScheduleChangeEventSchedule Changing to C:\Users\jlau\Documents\Xibo Library\5.xlf11/15/2016 11:19:33 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 47ff29524ce1b11/15/2016 11:19:33 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 53654d56726e011/15/2016 11:19:34 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:19:34 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 522caef6e13cb6c9fe5fac15dde59ef711/15/2016 11:19:34 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:19:35 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:19:35 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 11846d5d9f686fb75fc9dad0b19ca9de11/15/2016 11:19:35 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:19:36 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:19:36 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:19:45 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:19:45 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:19:45 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(307,91,669,1045,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:19:45 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:19:45 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:19:46 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:19:46 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:19:50 AMRegisterAgentThreadRegisterAgent - RunThread Woken and Lock Obtained11/15/2016 11:19:50 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:19:50 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:19:50 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(1365,665,0,0,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:19:50 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:19:50 AMUI ThreadMainForm - DurationElapsedEventAll Regions have expired. Raising a Next layout event.11/15/2016 11:19:50 AMUI ThreadMainForm - ScheduleChangeEventSchedule Changing to C:\Users\jlau\Documents\Xibo Library\5.xlf11/15/2016 11:19:50 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 47ff29524ce1b11/15/2016 11:19:50 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 53654d56726e011/15/2016 11:19:51 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:19:51 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 522caef6e13cb6c9fe5fac15dde59ef711/15/2016 11:19:51 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:19:52 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:19:52 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 11846d5d9f686fb75fc9dad0b19ca9de11/15/2016 11:19:52 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:19:53 AMLogAgentRegisterAgent - RunThread Woken and Lock Obtained11/15/2016 11:19:53 AMRequiredFilesAgentThreadRequiredFiles - ReportInventoryReporting Inventory11/15/2016 11:19:56 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:19:56 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:20:02 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:20:02 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:20:02 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(307,91,669,1045,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:20:02 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:20:02 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:20:06 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:20:06 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:20:07 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:20:07 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:20:07 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(1365,665,0,0,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:20:07 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed11/15/2016 11:20:07 AMUI ThreadMainForm - DurationElapsedEventAll Regions have expired. Raising a Next layout event.11/15/2016 11:20:07 AMUI ThreadMainForm - ScheduleChangeEventSchedule Changing to C:\Users\jlau\Documents\Xibo Library\5.xlf11/15/2016 11:20:07 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 47ff29524ce1b11/15/2016 11:20:07 AMUI ThreadMainForm - DestoryLayoutCalling Dispose on Region 53654d56726e011/15/2016 11:20:08 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:20:08 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 522caef6e13cb6c9fe5fac15dde59ef711/15/2016 11:20:08 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:20:09 AMUI ThreadRegion - SetNextMediaNodeNew media detected text11/15/2016 11:20:09 AMUI ThreadRegion - CreateNextMediaNodeCreating new media: text, 11846d5d9f686fb75fc9dad0b19ca9de11/15/2016 11:20:09 AMUI ThreadRegion - StartMediaStarting media11/15/2016 11:20:13 AMScheduleAgentThreadScheduleAgent - RunThread Woken and Lock Obtained11/15/2016 11:20:13 AMScheduleAgentThreadScheduleManager - GetScheduleXmlStringGetting the Schedule XML11/15/2016 11:20:16 AMScheduleManagerThreadScheduleManager - RunSchedule Timer Ticked11/15/2016 11:20:16 AMScheduleManagerThreadScheduleManager - LoadNewScheduleLayout has invalid dependent: 11/15/2016 11:20:20 AMUI ThreadMedia - SignalElapsedEventMedia Complete11/15/2016 11:20:20 AMUI ThreadRegion - DurationElapsedEventMedia Elapsed: 11/15/2016 11:20:20 AMUI ThreadRegion - SetNextMediaNodeMedia Expired:(307,91,669,1045,text,) . Reached the end of the sequence. Starting from the beginning.11/15/2016 11:20:20 AMUI ThreadMainForm - DurationElapsedEventRegion Elapsed”
“2016-11-15 22:20:51”,“XMDSSoap4”,“RegisterDisplay”,"serverKey: REMOVED, hardwareKey: REMOVED, displayName: WAREHOUSETV1"
“2016-11-15 22:20:51”,“DisplayProfile”,“LoadDefault”,“Load Default windows”
“2016-11-15 22:20:51”,“Display”,“Touch”,“IN”
“2016-11-15 22:20:51”,“XMDSSoap4”,“RegisterDisplay”,“<?xml version="1.0"?>
“2016-11-15 22:20:55”,“XMDSSoap4”,“MediaInventory”,””
