I’m following the next link
I finished the setup successfully but i have a problem when try to login on xibo cms.
if i try to enter the cms web site, redirects me to adfs logon portal.
if I enter my credentials it works correctly
but if I access directly from the adfs test portal (http://adfs.site.com/adfs/ls/idpinitiatedSignon.aspx) and i select xibo, it log me automatically.
I need to bypass adfs portal and logon without put credentials.
Thanks!
