I active the debug option in my settings but there is no error in the log in docker-compose logs :
$samlSettings = array (
'workflow' => array(
// Enable/Disable Just-In-Time provisioning
'jit' => true,
// Attribute to identify the user
// if set to nameId then the NameID from SAML will be taken and used as the
// username in Xibo.
'field_to_identify' => 'UserName', // Alternatives: UserID, UserName, email
// Default libraryQuota assigned to the created user by JIT
'libraryQuota' => 1000,
// Initial User Group
'group' => 'Users',
// Home Page
'homePage' => 'icondashboard.view',
// Enable/Disable Single Logout
'slo' => true,
// Attribute mapping between XIBO-CMS and the IdP
'mapping' => array (
'UserID' => '',
'usertypeid' => '',
'UserName' => 'uid',
'email' => 'mail',
// Configure the IdP and SP
'strict' => false,
'debug' => true,
'idp' => array (
'entityId' => 'xxxxxxxx/idp/shibboleth',
'singleSignOnService' => array (
'url' => 'https://xxxxxxx/idp/profile/SAML2/Redirect/SSO',
'singleLogoutService' => array (
'url' => 'https://xxxxxx/idp/profile/SAML2/POST/SLO',
'x509cert' => 'xxxxxxxx',
'sp' => array (
'entityId' => 'https://xxxxx/saml/metadata',
'assertionConsumerService' => array (
'url' => 'https://xxxxx/saml/acs',
'url' => 'https://xxxxx/saml/sls',
'NameIDFormat' => 'urn:oasis:names:tc:SAML:2.0:nameid-format:emailAddress',
'x509cert' => 'xxxx',
'privateKey' > 'xxxxx',
'security' => array (
'nameIdEncrypted' => false,
'authnRequestsSigned' => false,
'logoutRequestSigned' => false,
'logoutResponseSigned' => false,
'signMetadata' => false,
'wantMessagesSigned' => false,
'wantAssertionsSigned' => false,
'wantAssertionsEncrypted' => false,
'wantNameIdEncrypted' => false,
My IDP is a shibboleth and return to xibo with no problem. I thinks the problem is the jit but there is no logs about this.
thanks
