Thanks Alex and Peter for helping me.
I am using Android Minix 5 mini with latest version (4.4.2).
The file is playing well on my Windows PC with Chrome and IE.
Do you have any other ideal with this version of Android and HTML5 animation like this ?
I’m on a Corei5 with a nvidia graphics card and your animations drop frames for me. There’s no way an ARM CPU is going to be able to handle that kind of thing.
You’d need to build it as a video I think if it needs to look exactly as it does now.
Thank Alex,
I dont know why the animation play quite well on HTC 8s Windows Phone with very low CPU Rate.
The first time it load quite long but after that the animation played well not the same as Minix.
So i dont think the CPU and GPU cause this problem.
