Recently bought another T95 Android Unit with ASOP 7.1, then side loaded the Xibo 1.7 client and licensed it.
However when I assign the RTSP Layout all I see is a black screen.
This layout is working on other players, no blacklisted URLs / videos are listed.
In fact the logs are pretty much empty.
Is there a client or player setting that I’m forgetting?
It’s very odd the stream is playing
However I can only get audio and no video from the RTSP stream.
Then tested the RTSP stream on the same Android device using Kodi.
The Kodi App played back both audio and video just fine.
Which seems to rule out any possible bandwidth issues.
Also turned on auditing and received the following…
76554
2018-06-07 09:49:10
Client
onHandleIntent
XMDS intent completed at 2018-06-07T09:49:10.687-05:00. There are 2 HTTP client connections in the pool and 2 idle.
76553
2018-06-07 09:49:10
Client
onHandleIntent
XMDS intent received at 2018-06-07T09:49:10.312-05:00. There are 2 HTTP client connections in the pool and 2 idle.
76552
2018-06-07 09:44:10
Client
onHandleIntent
XMDS intent completed at 2018-06-07T09:44:10.785-05:00. There are 2 HTTP client connections in the pool and 2 idle.
76551
2018-06-07 09:49:10
XMDSSoap4
SubmitLog
XML log: onHandleIntentXMDS intent completed at 2018-06-07T09:44:10.785-05:00. There are 2 HTTP client connections in the pool and 2 idle.onHandleIntentXMDS intent received at 2018-06-07T09:49:10.312-05:00. There are 2 HTTP client connections in the pool and 2 idle.onHandleIntentXMDS intent completed at 2018-06-07T09:49:10.687-05:00. There are 2 HTTP client connections in the pool and 2 idle.
76550
2018-06-07 09:49:10
Client
onHandleIntent
76549
2018-06-07 09:44:10
Client
onHandleIntent
76548
2018-06-07 09:49:10
XMDSSoap4
SubmitLog
I rolled the Android Rom back to a compatible 7.1.1 and the display issue went away.
Curious do see any video jitter issues with RTSP on the 1.7.6 Xibo client?
