I’m in the process of moving to Docker 1.8.2 from windows server iis 1.7.9 and I’ve hit an error with my XML RSS feeds
I have a script that extracts the RSS from Sharepoint using windows auth and spits out an XML file into the userscripts folder.
I was having some issues with the new 1.8.2 installation not showing my XML file and complaining about incorrect encoding and not being able to change it.
My script was outputting UTF-8 XiboDocker1.8.2 seems to want UTF-16.
I’ve now realised that the ticker in my layouts isn’t getting any data from the XML I have in /userscripts
Or from the old Xibo 1.7.9 server (xml files just dumped in the www folder)
But it will pick up data from external XML RSS feeds.
I tested this by downloading the working RSS and putting that in my /userscripts folder
I’m running HTTP and the XML files are being called from the fully qualified name in my layouts
http://xibo.internal.here.there.com/xibo/userscripts/list.xml
and my old server
http://XiboWin2012R2.internal.here.there.com/xibo/list.xml
my clients can see the XML data from InternetExplorer/Edge hitting http://xibo.internal.here.there.com/xibo/userscripts/list.xml
Are there some sort of restriction in what will run from the userscripts folder?
I can call an HTML file I have in the userscripts just fine
Cheers
Jeremy
