Rss ticker - rtl
I’m using the RSS Ticker widget in Xibo to display Hebrew content.
However, there’s an issue with the way punctuation is displayed:
When a sentence ends with a period . or quotation marks ", the punctuation appears at the beginning of the line instead of at the end.
e.g.
I use this rss:
https://www.ynet.co.il/Integration/StoryRss1854.xml
how can I fix it?
Is there no option to set text direction?
I only see this option in:
But when I set the text direction to RTL and use the “marquee right” effect, it breaks - nothing is displayed.
