Since I can’t seem to figure out why my embedded HTML ticker won’t work, I’ve tried playing with Xibo’s Ticker Widget. And I can’t seem to get that to work either.
As I’m sure you can see, I had to strip some of the tags from the feed to return results, I wonder if this is the same issue you have been running into? The tags I stripped from the feed were cdata, div and a. I also chose the Template Title only but this doesn’t matter so much if you intend to override the Template. I have not applied any styling to the Ticker as it is a simple test to see if the Feed will return data.
I hope this helps you to make a start on your own Ticker.
