I am working with an android player. I configured a RSS feed but I can only see the first item and sometimes other items underneath it. No animation or scroll what so ever despite everything I try like marquee up, right, left etc.
I believe I’ve replied to you in your other topic, I don’t think you have the effect selected or the player hasn’t updated the layout since you selected it.
I did ask you some questions as well, in the other topic, you can reply here since you created new topic specifically about this issue.
Ok, thanks.
I can clearly see that the layout is updated since the font size keeps changing when I change the effect.
When I changed to “Tile Slide” I finally see something is moving. Other effects doesn’t work.
How can I change the time between items? I want to make it quicker in order to see it it’s moving.
As far as I can tell, the RSS is working OK with all the effects besides the Marquee. It’s fine for us but we have another issue. We display RSS in Hebrew and I see that some of the sentences are cut and after that I can see a word from another item so the information and the flow between items is not good.
