Round Robin Nested Playlists
Version 4.4.0
Windows Player
4 R406.3
I have two sets of contend that I want to round robin
A1
A2
B1
B2
B3
B4
I set up a playlist with A content and then a nested playlist with B content. When I scheduled this it only played B1 when it came the nested playlist even though I had it set to round robin.
I also tried two nested playlists, layouts and nest playlists as well as two campaigns set to round robin.
Is what I am try in do possible in Xibo?
Thanks!
Hi bmckamie,
Thank you for reaching out to Xibo Community!
I think you can achieve showing your playlists in a round-robin style if you create the 2 playlists, A and B first, and then create a layout and use a playlist widget. Inside that playlist widget, use a subplaylist, which will then have both playlist A and B. From there, you can set it to play as ‘Round Robin’.
Create a layout with a playlist.
Enter the playlist, then create a sublaylist to configure both playlist A and B.
I hope this helps!
Kind regards,
Jerry
JerryW,
Thank you very much for responding and walking me through this.
I tried your method and it worked! Thank you very much. I really appreciate it.
Thanks again,
Blane
