I want to get external data live on screen, (eg every 1 minute)
So I set the task FETCH REMOTE DATASETS to 1 minute (Schedule to 1 * * * * *)
The created a dataset with remote and tested the connection : OK
On EDIT DATASET / ADVANCED I set the Refresh on CONSTANTLY
When I check the data in the dataset it seems to refresh every hour (The LAST SYNC)
What do I need to change or set that the sunc is every minute?
I’m using XIBO V2.0 ALPHA
(ps, a layout is created and scheduled on a android player and showing data )
